Old 07-29-2013, 03:20 AM   #1
hameeds01
Drives: Yaris 2008
Yaris AC Compressor issue
Hello Guys
i have Yaris 1.3L equipped with 2SZ-FE and the compressor is 5se09c. AC runs pretty well Cooling is gud, the problem that i am facing is that when i Switch ON the AC it makes some grrrrrr grrrrrr sound only @ 750 to 900RPM Range if the Engine RPM goes above or below that range it runs silent.
to test it yesterday i removed the belt & drive all the pulleys manually with hand in order to find any pulley bearing issue bt i didnt find any thing,
when i rotate the compressor pulley it was running lil harder than others is it Normal?? Then Engine was in off condition
Regards
asad
hameeds01 is offline   Reply With Quote
Old 07-29-2013, 06:21 AM   #2
One of mine recently started doing the exact same thing. I think it may be the early stages of the bearings going.
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
