Old 07-29-2013, 12:16 PM   #1
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
Driving Lights Mounting?
I'm looking to add driving lights to my '08 HB for night driving on rural PA roads at night. My idea is to mount them on the bumper by using universal L brakets on the outside with a metal plate on the inside for support, sandwiching the plastic. My question is if anyone knows if the urethane will be able to handle the weight/stress, or if there is another sollution for support. Unfortunately PA has a stupid rule that driving lights have to be 20" apart center-to-center so center mount is out
BobTheYaris is offline   Reply With Quote
Old 07-29-2013, 02:04 PM   #2
You may just want to go with a set of fog lights mounted in the OEM position. I find that they make a world of difference on our unlit roads.
For actually mounting driving lights to the bumper skin, if you add the reinforcement behind to prevent the stress against a single though hole, they should be fine.
Old 05-06-2014, 09:02 PM   #3
X92Festy
Drives: 2008 Yaris 2 dr...Blue
Do our cars come with the wiring for the fog lights even if it didn't have it from factory?
X92Festy is offline   Reply With Quote
Old 05-06-2014, 09:29 PM   #4
Yes and no. The wiring is present from the headlight switch through the under-dash fuse box to the under-hood fuse box. From there to the light locations it is not present. Micro Image sells a completely plug and play kit for the fogs, which includes the harness from the fogs to the under-hood fuse panel.
Old 05-07-2014, 08:36 AM   #5
BobTheYaris
Then out of curiosity, what is the wire and plug that is sealed off behind the bumper under the driver side headlight?
Sent from my iPod touch using Tapatalk
Old 05-07-2014, 10:03 AM   #6
Good question. I would need to see a picture of it to tell you for sure. If your Yaris does not have AC, it could be the ambient temperature sensor connector for instance.
Old 05-24-2014, 01:42 PM   #7
Dragunov
Drives: 2008 Toyota Yaris Hatchback
Hi, Bob the Yaris, I had the same problems some time ago and this is what I have since then, I had HID's installed but the ones that is one HD bulb for High and Low and them install another pair on the Fog lights and the wire harness comes with the option of activating the High Beam the Fog lights will turn on by itself or the opposed to that.........
Dragunov is offline   Reply With Quote
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
wire size for trailer lights Connoisseur_of_fine_cars DIY / Maintenance / Service 0 11-03-2011 08:09 PM
I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe PETERPOOP Off-topic / Other Cars / Everything else Discussions 21 05-16-2010 03:19 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
