Old 08-05-2013, 06:59 AM   #1
yarismo
yarismo's Avatar
Drives: Yaris HB luna
Less power !!?!
Hello, during these last 3 days i experienced some troubles with my 2009 Yaris.
It is powered by a 2NZ-Fe. Here what i noticed:
- engine On + A/C On = engine vibrating massively as if it is going to shutt donw
- engine On + head lights On = when i apply gas lights become brighter , when i release gas lights become less bright and engine starts vibrating
- less power on the road
- A/C goes Off and On all the way
What i did:
- checked air filter ( replaced new one)
- thought may be poor gas and i filled it with new one
- checked A/C cooling liquide and its fine
What do you suggest???
yarismo is offline   Reply With Quote
Old 08-05-2013, 07:17 AM   #2
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
I would inspect your belts, and possibly the alternator.
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 08-05-2013, 06:19 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
+1 for the alternator check.
Old 08-05-2013, 09:37 PM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Your symptoms sound like it's the battery.
Either weak from not being charged, or just old and ready to be replaced.
How old is your battery?
Old 08-05-2013, 09:54 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
yep, electrical load issue have battery and alternator testes
Old 08-24-2013, 11:44 PM   #6
X2 on this ^
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
