Old 03-28-2007, 06:34 PM   #1
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Tinted Liftback Tail Lights... A Little different way.
Rather then using a film, or the VHT Nite Shades spray tint, I instead got a can of VHT Window Tinting spray tint.
Once all prep is complete, the VHT gets put on with a heavy coat, looks almost like black water, and allowed to drip down the light assy., as it "self levels" itself out.
One coat is all thats needed, and you can follow up with a final clear coat if wanted.
NOTE - this will ONLY give your tails a smoked look, not a dark black limo tint look like many coats of Nite Shades will. This is all I wanted, so I'm happy with the results.
Old 03-28-2007, 06:38 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Nice job, looks good
Old 03-28-2007, 06:41 PM   #3
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
Will that tint hold up to water pretty good? Or will it fade after so many washes....Good Job
YamilR is offline   Reply With Quote
Old 03-28-2007, 06:46 PM   #4
Chris07LB
Chris07LB's Avatar
Its actually called VHT Window Tint, as in they use it to tint windows normally... so yes. When tinting headlights or tail lights, it gives a smoked apperance with no chance of making one darker then the other, or not spraying correctly like some may experience when using the Nite Shades by VHT.
Window Tint Spray - heavy thick coat, allowed to run off and dry.
Nite Shades Spray - light coats until desired darkness is reached.
I have now used both products, and like them both. Smoked is all I was after with this set.
Old 03-28-2007, 07:01 PM   #5
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
shweet!
Old 03-28-2007, 08:06 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
I just ordered some of that window tint from summit racing (cheapest I could find w/shipping). Washington state laws don't let you blackout your tails (or any of the lights for that matter) but im sure this won't get me into trouble... i hope . If it works, i'll probably do my LeBaron as well.
Old 03-28-2007, 08:10 PM   #7
Chris07LB
Chris07LB's Avatar
Brake lights, signal lights, and reverse lights all shine bright enough to keep Johnny law happy.
Old 03-28-2007, 08:26 PM   #8
absenter
absenter's Avatar
Drives: Black '07 Liftback
So what is the process of this exactly? Just remove the tails and start sprayin? Still new to all this jazz.
thank ya!
VI VI VI
absenter is offline   Reply With Quote
Old 03-28-2007, 08:28 PM   #9
MudBug
Drives: 07 Yaris
I'm gonna guess those are just hubcaps. If they are would you mind telling me about them? I like that look.
MudBug is offline   Reply With Quote
Old 03-28-2007, 09:07 PM   #10
ChinoCharles
Drives: LB
thank ya!
The main thing you want to make sure of is that there is NO dirt, oil, hair, dust, or anything else on the light when you start spraying. A lint-free cloth and a bit of diluted rubbing alcohol will work wonders. I actually used Windex because I was too lazy to go to the store and that worked fine, too. They still look good as new.
Chris, can I tell you how fucking awesome your car looks? I love how you keep simplifying all of the jagged visual edges to give it an almost surreal, simplistic exterior look. You're on your way to one sick ride!
Old 03-28-2007, 09:09 PM   #11
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
That's pretty nice looking but the smoked look isn't for me anymore.
Old 03-28-2007, 09:45 PM   #12
absenter
absenter's Avatar
Thanks Chino, with all this extra time on my hands, I've been ordering stuff online like mad. Looks I'll be making a purcahse soon. I think I might go a little darker than Chris though.
Is there anything I should know on removing the tails?
VI VI VI
Old 03-28-2007, 10:33 PM   #13
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Hi Chriss where did you found that Wheel? or wheel cover? i have been looking for that for a long time.
Old 03-29-2007, 08:55 AM   #14
Chris07LB
Chris07LB's Avatar
As for the tails.... pop off the 2 plastic grills in the hatch area, then take a 10mm socket to remove 2 nuts per housing. Tug them from the outside, and unplug the 1 wire harness. Simple.
If using the Window Tint Spray, do NOT sand or scuff the surface.. it warns of this on the can as well. Any scratches or scuffs will be filled in by the tint spray, and will be seen!
As for the hub caps, got 'em off eBay. They are getting powdercoated Polar White next week.
Chino, thanks man, its just a lil side thing for me.. tweeks here and there nothing major or expensive. Got my other babies for that.
Old 03-29-2007, 08:58 AM   #15
absenter
absenter's Avatar
Thank ya!! Purchasing the spray as we speak. Much appreciated.
VI VI VI
Old 03-29-2007, 09:01 AM   #16
Chris07LB
Chris07LB's Avatar
yup.
Old 03-29-2007, 09:57 AM   #17
Astroman
Modded Moderator
Astroman's Avatar
Has anyone used this for actually tinting windows?
Old 03-29-2007, 10:11 AM   #18
jamal1984
Can you link me the page for that? really appreciate.
i want to know where can i get tinted tail lights??? lbguy53 Cosmetic Modifications (Exterior/Interior) 27 03-24-2007 05:36 PM
aftermarket tail lights or tint? jamal1984 Cosmetic Modifications (Exterior/Interior) 17 01-31-2007 03:00 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
T Sport tail lights? SEaton Items for Sale by private party 106 08-31-2006 04:21 PM
