#1 |
Auris engine
Hi, may be this will sounds strange, but i wonder if the Auris engine 1.6 can fit a 2006 hb yaris 2nz-fe !?!
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Fit? Sure! Easy? Probably not...
#3 |
Specs. Please.
#4 |
better to do the auris 1.8.
#5 |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
1ZR-FAE
The Toyota 1ZR-FAE is a DOHC, 16-valve, 1.6 L (1,598 cc) engine also equipped with Dual VVT-i and Valvematic. Output for this engine is rated at 132 hp (97 kW) at 6400 rpm and 118 lb·ft (160 N·m) of torque at 4400 rpm for the Avensis. Compression ratio has been increased to 10.7:1, red line is at 6600 rpm. Valvematic varies the intake valve lift between 1mm and 11mm according to load and RPM. |
#6 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
1.6 with 130hp.... wow
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
#7 |
![]() ![]() ![]() Drives: Yaris sedan Join Date: Jan 2009
That's a big waste of cash.
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Can I change my yaris engine from 1.3L to 1.8L | Rami yaris | Performance Modifications | 9 | 06-11-2012 10:21 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| 90% on short trip. What to do to protect engine? | lh59 | DIY / Maintenance / Service | 22 | 12-17-2008 09:02 AM |
