Old 08-07-2013, 06:03 PM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Slight hesitation.
I am getting a slight hesitation on exhilaration. It sounds coarse too. Like this ; i press the pedal it goes but it sound different. Like a coarse "wooaaw" sound when i change to second gear. I did change the oil filter, engine oil to full synthetic, and air filter. It has 105 678 km on the clock. 7 years had no problems until now.
Few things i realize this is mostly due to good OLD ware and tare.
1.Slower, sluggish not smooth.
2.The suspension; well you feel and hear every bump and imperfections on the road.
3.Gearbox notchy
4. Hearing noises etc lol
5. Louder as F#$k.
That is all.
Old 08-08-2013, 09:07 AM   #2
alanwagen
3.Gearbox notchy
5. Louder as F#$k.
That is all.
Check you air filter box to be sure the it is on correctly. It is sort of tricky and may not be on all the way. The tabs do not want mesh in the notches. That would explain the throttle noise.
steering wheel slight vibration high speed??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 10-01-2012 06:36 PM
Hesitation at all speeds soloecho2 DIY / Maintenance / Service 3 10-22-2011 10:00 AM
hesitation problem larryn2o DIY / Maintenance / Service 9 07-21-2011 07:47 PM
slight clutch kickback after engine start?? marcus DIY / Maintenance / Service 0 09-17-2010 11:06 AM
slight clutch kickback after engine start?? marcus DIY / Maintenance / Service 0 09-17-2010 11:05 AM
