Old 03-29-2007, 04:26 PM   #1
deebrown
Drives: Sedan
Sandbags in Trunk?
I'm having a problem with the yaris being blown around in the wind on the highway - i was thinking about putting sandbags or free weights in the trunk of the car (it's a sedan) to weigh it down (and thus hopefully making it more stable). Has anyone done this and, if so, what was the loss on mpg?
deebrown is offline   Reply With Quote
Old 03-29-2007, 04:31 PM   #2
pc1x1
Drives: Yaris 2007 Liftback (Jan 07)
Common sense more weight = less mpg. What you can do is a ratio, Power/Weight = Power/Weight + sandbacks, then check MPG and multiply it by your normal MPG.
pc1x1 is offline   Reply With Quote
Old 03-29-2007, 04:35 PM   #3
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
You so SMART!
Nutzoids is offline   Reply With Quote
Old 03-29-2007, 04:40 PM   #4
Kitt
Kitt's Avatar
Been there, done that! and i have a LB it's scary man! 120K/h and the wind moves you!!!
Old 03-29-2007, 06:36 PM   #5
KSIbucky
KSIbucky's Avatar
what i have seen is tires that respond to wind but idk theres not much you can do. you would have to put a lot of weight wouldnt you?
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 03-29-2007, 06:53 PM   #6
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
I have roughly 150 pounds of stereo junk in the trunk of my sedan, and all it helps to do is increase the body roll of your car.
If you want to stop getting pushed around by crosswinds, you have a few options:
A. Buy a bigger car
B. Lower that beech!
C. Follow option B and also buy some bigger rims & really wide low profile tires
D. This option is if you refuse to lower it...buy wide low pro tires and rims to mount them on, buy sway bars,struts,and a strut tower brace...these will help stiffen the car up a little bit and perhaps help with the wandering in crosswinds.
E. Just forget the other options and lower it because it is the best option second only to option A.
Old 03-29-2007, 06:58 PM   #7
BailOut
Steals terrorist's lunch
BailOut's Avatar
I'm curious if you folks experience higher winds or just different vehicle behavior than I do.
The area I live in gets 90 MPH winds several times per year and lots more days of gusts up to 75 MPH and while I have definitely felt the wind resistance and the Yaris leaning, maybe even being pushed a touch, I have never even come close to getting blown out of my lane, or even moved that much in it.
Is it just the leaning or feeling of being pushed that bothers you folks so?
- Brian
Share the Road
Old 03-29-2007, 07:01 PM   #8
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I lowered mine 1.9 front and rear and it made a huge difference on the highway. Much better.
SPONSORED BY
Old 03-29-2007, 07:41 PM   #9
deebrown
Drives: Sedan
How to lower car
Ok, can anyone tell me how to lower the car and how expensive such a process is? Also, my last car was a dodge neon (very low to the ground and no wind problems) but i was constantly "bottoming out" the car as it was so close to the ground - do any of you who have lowered your car have this problem?
Thanks,
Dee
Old 03-29-2007, 08:21 PM   #10
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
I'm curious - there's a couple of threads on this subject and a number of posters suggesting that you fit swaybars..
Do your North American Yarii not come with an OEM front swaybar??!?
Here's a pic of the one that came standard on my liftback:
Razr is offline   Reply With Quote
Old 03-29-2007, 08:27 PM   #11
brickhardmeat
Lonesome Cowboy
chris did a "how to" on his tanabe spring install, whatever springs you use go in the same, you could probably get them installed for about 200. dunno, luckily I have a friend who helped me out, tools and all, it's not a big deal just don't let the car fall on your head
SPONSORED BY
Old 03-29-2007, 08:43 PM   #12
Spades
The Hated One
Spades's Avatar
I haven't checked to see if my US sedan comes equipped with a front swaybar...I assumed it hadn't due to the low cost of the car and pronounced body roll.
I haven't noticed much problem being pushed around from lane to lane either...I notice a strong gust puts some resistance on the steering wheel, but it never was strong enough to even come close to moving me into another lane.
Old 03-29-2007, 10:07 PM   #13
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
I have a Sedan and yes the American models to come with a front sway bar.
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 03-29-2007, 10:13 PM   #14
Spades
The Hated One
Spades's Avatar
yes, but does yours have the swaybar because it is an S coupe? or do they all come with them?
Old 03-29-2007, 10:19 PM   #15
Razr
YRS WHOR
Razr's Avatar
Why don't you turn your wheels to full lock and take a look Spades :)
Old 03-31-2007, 02:18 PM   #16
mkaresh
Drives: Mazda Protege5
It's not so much a function of weight as the design of the body. Apparently the upper body of the Yaris catches the wind rather than deflecting it around the car.
I'm surprised to hear this is a problem with the sedan, because it's not as tall as the hatch and presents less area to crosswinds.
truedelta.com
Vehicle reliability, fuel economy, price comparisons
mkaresh is offline   Reply With Quote
Old 03-31-2007, 03:16 PM   #17
deebrown
Drives: Sedan
possible solution?
"I'm surprised to hear this is a problem with the sedan, because it's not as tall as the hatch and presents less area to crosswinds."
Can the problem then, in your opinion, be corrected by lowering the car?
Old 03-31-2007, 07:06 PM   #18
mkaresh
Probably not to a significant extent. You can't lower it more than an inch or two. The shape of the upper body is probably the largest factor, and you can't do anything about that.
truedelta.com
trunk sub pix! drell42 In Car Entertainment + Electronics (audio / video / alarm) 21 07-26-2009 09:25 PM
Electronic Trunk Release Problem jonr0613 DIY / Maintenance / Service 5 09-08-2007 06:13 AM
Help with Amp Ground in Trunk Meldav86 In Car Entertainment + Electronics (audio / video / alarm) 5 03-22-2007 01:31 PM
Trunk issue Lowfront In Car Entertainment + Electronics (audio / video / alarm) 1 09-24-2006 06:55 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
