Old 08-18-2013, 05:05 PM   #1
2005vitzRS
2005vitzRS's Avatar
Drives: 2005 Vitz RS, NCP91, Manual
Yaris/Vitz RS hatch DIY gas struts repair
Hey guys. When opening the boot (trunk) of my 2005 Vitz its started to stick and does not open all the way up.
Any ideas on a DIY fix?
2005vitzRS is offline   Reply With Quote
Old 08-18-2013, 05:12 PM   #2
That means that it is time to replace the gas struts.
Old 08-18-2013, 11:35 PM   #3
2005vitzRS
2005vitzRS's Avatar
Cheers for that. Was just wondering if there was a DIY way of repairing them. Will take the car in and get it done.
Old 08-18-2013, 11:59 PM   #4
There's a thread on here about aftermarket ones, which shows the process of replacing them. Basically you open the hatch and support its weight, which replacing one at a time. The struts mount to balls, which have a spring clip. Remove the spring clip and the end of the strut lifts right off of the ball.
If you do go with aftermarket ones, make sure that they have an equivalent lift rating (~90 to 100 lbs) and that they are the dampened type (which open quickly and then slow down as they approach their full open position.
Old 09-19-2013, 12:13 AM   #5
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
My hatchback had this problem, particularly on a hot day.
I fixed that by rubbing grease around the strut shaft and then sprayed WD-40 onto near the opening where the shaft glides into the strut body.
(the grease will dry out after around 3-4 months though)
Mittelklasse is offline   Reply With Quote
DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS auxmike DIY / Maintenance / Service 50 12-10-2024 12:39 PM
DIY: Hatch Popper using Scion IQ Hatch Handle (2006-2011 Liftback) CTScott DIY / Maintenance / Service 15 12-30-2015 06:27 PM
Rear Hatch Gas Springs - don't lift anymore mrrock General Yaris / Vitz Discussion 21 09-28-2011 05:50 PM
Rear Hatch Gas springs - don't lift anymore mrrock General Yaris / Vitz Discussion 0 01-14-2009 10:09 PM
DIY: Yaris Hatch grill block/air dam yarswiss DIY / Maintenance / Service 0 10-26-2008 06:52 PM
