Old 08-25-2013, 01:08 AM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Question Wideband Options
So I am fed up with the junk UEGO from AEM. I have had 3 sensors and 2 gauge units. AEM says that there is something wrong with my car, but my tuner has confirmed that the exhaust setup I have is very similar to many, many vehicles they have dealt with to include 600-1000whp beasts which do not have the issue. They have seen however have had issues with the UEGO kits in the past as well. I figured that I would chime in here to see about sharing and getting input.
Option 1:
Autometer Cobalt Wideband Kit
Option 2:
MTX-L: Wideband Air/Fuel Ratio Gauge
I haven't really seen much else our there that piqued my interest in the least. Has anyone had any experiences with either of the two products listed above? Sure, the Cobalt would be idea because of the fact that it would make all my other gauges since they are all Cobalt, but for the most part it is more expensive.
Old 08-26-2013, 02:53 PM   #2
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
What was your exact problem with the AEM one? I'm just a bit curious. I had the MTX-L on my FC and never had a problem with it. You can also connect other innovate gauges together and use their pocketlogger if you ever wanted to.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 08-26-2013, 03:01 PM   #3
It's a sensor and a gauge. It's not possible they were all bad. I've sold probably twenty of those, and I run that same one on my car. NO PROBLEMS.
AEM *might* be right.
Old 08-26-2013, 07:42 PM   #4
fnkngrv
fnkngrv's Avatar
^ you can have your opinion, but it doesn't actually provide any feedback in regards to my question.
Old 08-26-2013, 07:50 PM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
^ no experience per se, but I've had great luck with the Innovate LC-2 wideband.
Old 08-26-2013, 09:36 PM   #6
Well, it does actually provide feedback. You should revisit the idea that there is something wrong with the placement, or the bung, or something to cause all that failure.
That's feedback; I'm sorry if it's not what you want to hear.
