Old 05-14-2006, 03:38 AM   #1
birdy
I stay G'd Up
birdy's Avatar
Drives: 02 wrx wagon
Send a message via AIM to birdy
will it fit?
17x8.5 25mm offset?
I would get the black ones and then slam the car as much as I can. The car is slow so might as well make it look good.
birdy is offline   Reply With Quote
Old 05-14-2006, 12:31 PM   #2
Ron
Drives: BBM Yaris HB
i personally think rim width is too wide, and offset is too low. if it was 17x7.5, offset ~40mm, then you'd be ok. really hard to find a nice wheel with lots of lip in a higher positive offset. they look nice though!
Ron is offline   Reply With Quote
Old 05-14-2006, 06:51 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
From what I've been told here they might not be able to fit over the front brakes, etc.
Colin Chapman disciple
Old 05-14-2006, 07:18 PM   #4
Ron
i dont see why a 17" wheel will have any problems clearing the front brakes
Old 05-14-2006, 09:15 PM   #5
birdy
I stay G'd Up
birdy's Avatar
well the rims fit on scions, i was more concerned about rubbing
Old 05-14-2006, 09:22 PM   #6
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
If you want the look of a multi-piece wheel, you should buy a multi-piece wheel. :P
Idjiit is offline   Reply With Quote
Old 05-15-2006, 10:18 AM   #7
why?
why?'s Avatar
Drives: Yaris LB
Its the +25 mm part, not the size part.
I doubt you'd have much problems with rubbing.
Old 05-15-2006, 03:31 PM   #8
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Do we know the stock offset on the Yaris? I think it's +40 or +42; I know it's higher than the xB, which is +38.
If you lower the car with a +25, you might have to worry about rubbing. Tirerack.com is recommending +40 and higher for the Yaris. If anyone is in the Milwaukee, WI area, I'd be willing to slap on one of my wheels (+35) to see if it'd rub.
Old 05-15-2006, 03:56 PM   #9
Idjiit
5 Stars, Bitches
Isn't the offset completely dependent on the rim width? So +40 might be what they recommend for a 7" wide rim, but not necessarily for an 8.5" wide rim.
Old 05-15-2006, 04:50 PM   #10
birdy
I stay G'd Up
birdy's Avatar
yeah I know, but these are going to be my daily rims and they have a a high chance of getting screwed up. I am buying show wheels and they will be a lot more expensive.
Old 05-15-2006, 05:19 PM   #11
Idjiit
5 Stars, Bitches
Well, since you're so tactless about your opinion on everyone else's choices I'll just say that they're fugly as all hell and the fact that it's a poser rim makes it even worse. Please don't buy those.
Old 05-17-2006, 11:46 PM   #12
benfal2001
Drives: Red Milano FIT LX
So get a Fit it will fit
benfal2001 is offline   Reply With Quote
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 06:10 PM
Thule fit kit for Yaris !!! lappie General Yaris / Vitz Discussion 13 09-14-2017 04:29 PM
The Honda FIT... Leenis24 Off-topic / Other Cars / Everything else Discussions 198 08-09-2006 08:11 PM
Yari vs. Honda Fit nwdixieboy General Yaris / Vitz Discussion 78 05-24-2006 02:08 PM
How will this car do against other subcompacts (Fit, Versa) Mess11 General Yaris / Vitz Discussion 23 02-02-2006 12:27 PM
