Old 08-29-2013, 06:43 PM   #1
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Exclamation What's that clunkin' noise? I'll show you...
Well, that's not how I left you...
ohhh...
After driving who knows how fast for the last three + hours I finally figured out what that clunking noise was I had been hearing since right about when I got off the off ramp to my work. I could only hear it when I was dropping the clutch or over a large bump. I was pretty sure my exhaust had somehow worked itself loose so I figured "meh, I look at it when I get home and the engine cools off"...dumb.
I don't even know where the second bolt is. There was no trace of it other than the shiny ring where it used to be.
I had actually jacked the engine back up prior to taking these pics because I was worried about the AC line. The bracket on the engine side had come to rest on the line and as such has left a significant dent in the aluminum. The motor was resting on the AC line and the fender for hours, sometimes at higher than average speeds.
I pulled the engine mount, pulled the belt, pulled the water pump pulley, pulled the mount from the engine block, backed the broken bolt out, replaced the block mount, replaced the pulley, replaced the belt and replaced the engine mount. Now I am waiting on the two bolts from Toyota, they will be here in the AM. It took about 1.5 hours.
-Type 07 FFL-
My odometer 03/11
Old 08-29-2013, 08:05 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Holy shear force, Batman!
Old 08-29-2013, 08:29 PM   #3
There is also supposed to be a nut on the bottom side, so there are a total of three fasteners holding that puppy down.
Old 08-29-2013, 08:41 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
Thank you for reminding me Scott!! I noticed it was gone too and forgot to order it earlier. I just called back and made the cutoff.
-Type 07 FFL-
My odometer 03/11
Old 08-29-2013, 11:45 PM   #5
nookandcrannycar
The scariest thing is that (of all of the pictures that have been displayed recently) your bolt looks the 'most pristine' re condition. I hope the break is a result of your driving style (of course wishing it hadn't happened at all) and not a lack of quality re the bolt (which might 'afflict' those of us who drive like the L.O.L. going to church ).
Old 08-30-2013, 12:01 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
MORE LOW!
How does something like that even happen?
It takes a pretty hefty amount of force to shear like that.
Old 08-30-2013, 06:54 AM   #7
With the nut and other bolt being AWOL, my bet is that he was running with just one bolt and that one guy alone couldn't handle the force.
Old 08-30-2013, 09:58 AM   #8
mazilla
advocatus diaboli
mazilla's Avatar
My thought as well, and with the way I drive this car there is no way that one bolt could hang.
My Yaris is trying to kill me this last month! Haha, first the brakes now this.
-Type 07 FFL-
My odometer 03/11
Old 08-30-2013, 10:14 AM   #9
That's what you get for naming her Carrie!
Old 08-30-2013, 10:51 AM   #10
33OH
Drives: '08 Yaris
It's all that yellow paint weighing the motor down.
Old 08-30-2013, 11:08 AM   #11
nookandcrannycar
Thank you! Your input is reassuring.
Old 08-30-2013, 11:09 AM   #12
nookandcrannycar
Thank you! Likewise, your input is reassuring.
Old 08-30-2013, 11:11 AM   #13
nookandcrannycar
Old 08-30-2013, 11:11 AM   #14
nookandcrannycar
Old 08-30-2013, 02:04 PM   #15
justjesus
justjesus's Avatar
Drives: 2008 Liftback
that's nuts!
glad it wasn't anything worse
Old 08-30-2013, 04:24 PM   #16
mazilla
advocatus diaboli
mazilla's Avatar
The loaner! Mother in laws blue 07...I put those smoked signals on there, I had a set laying around and figured what the heck.
Luckily I went by Toyota to check the parts, they had ordered me the wrong bolts! They got the correct bolts on the PM order so I should still be good to go today. It feels strange being in a stock Yaris again, and an automatic at that. I keep trying to hit the clutch, lol.
-Type 07 FFL-
My odometer 03/11
Motion Auto Show 8/21/11 cali yaris California 2 08-20-2011 12:50 PM
Rockland Toyota's Scion Revolution 4.0 phyre76 NY / NJ/ CT / PA 70 08-11-2010 05:20 AM
ROCKLAND SCION'S FALL FESTIVAL 2009 9/13/2009 ROCKLAND TOYOTA NY / NJ/ CT / PA 18 09-15-2009 10:31 PM
ROCKLAND/SCION SUMMER SLAM 3.0 7/19/09 ROCKLAND TOYOTA NY / NJ/ CT / PA 198 08-05-2009 01:04 AM
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
