Old 09-04-2013, 06:37 PM   #1
Stacy Travis
Drives: 2007 Toyota Yaris
Error code C1241 after P0010
So I got my car back from the mechanic, P0010 cleared but it shows C1241. I know nothing about repairs so can someone tell me what this means? New battery, new alternator? It's something to do with the power supply.
Stacy Travis is offline   Reply With Quote
Old 09-04-2013, 07:29 PM   #2
C1241 is an ABS brake system error indicating low or abnormally high battery voltage the the ABS ECU.
Old 09-04-2013, 07:51 PM   #3
Stacy Travis
So what would have caused this after a cam sensor replacement?
Old 09-04-2013, 08:53 PM   #4
If the error clears and stays away then it is likely that they turned the ignition on with something disconnected. If it doesn't clear, then I would suspect a damaged wire going to the ABS ECU.
Old 09-04-2013, 09:31 PM   #5
Stacy Travis
Thanks! Back to the mechanic tomorrow.
Old 09-04-2013, 09:48 PM   #6
After you get this squared away, I would suggest looking for a new/better mechanic.
Old 09-05-2013, 06:03 AM   #7
Stacy Travis
I think I agree with you. I had no problems with this car until Good Year worked on it. This was actually the second mechanic in a week to work on my car.
Error code of P0010 on diagnostic test Stacy Travis DIY / Maintenance / Service 2 08-31-2013 08:44 AM
P0010 OBDII scan code yaitsme DIY / Maintenance / Service 2 04-08-2013 11:24 PM
Code p0010 Ckern67 DIY / Maintenance / Service 1 11-26-2011 10:57 PM
