Old 09-11-2013, 05:14 PM   #1
roy1447
Drives: 2007 Toyota Yaris HB
ABS wires
Hi; I have a 2007 Yaris HB. There are two wires, one white, one light Blue, coming out of the Front Drivers side speed sensor. They got broken off from wherever it is they are supposed to connect to. Does anyone know exactly where it is they are supposed to go? Thanks. P.S., the brake, airbag, and ABS lights are now lit on the Dash.
roy1447 is offline   Reply With Quote
Old 09-11-2013, 08:43 PM   #2
The airbag light shouldn't be lit for that, so you may have additional damage to the harness for the impact sensor on that side.
This image shows the routing of the ABS cable.
Old 09-12-2013, 06:10 AM   #3
roy1447
k, I'll check that out, but I'm still wondering where the two wires connect. Thanks.
Old 09-12-2013, 06:36 AM   #4
The two wires were part of the covered harness shown in that image. It sounds like that harness got chopped, so you will be looking to see how much of the harness is left. You will see the blue and white wires on the other side, when you find it.
Old 09-12-2013, 11:19 AM   #5
roy1447
O.K., Thanks! I'll let you know how I make out.
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 02:10 PM
Ultimate Turbo Pre-Install Guide Focus_Sh1ft Forced Induction Forum 7 09-14-2017 03:28 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
ABS brakes / Would you buy a Yaris without them? 3cyltrbo General Yaris / Vitz Discussion 66 03-26-2011 08:21 PM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
