#1 |
![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
getting at the clutch
I am noticing a shudder in the clutch now and then. My hatch has 388K.
Is it hard to get at the clutch to replace it???pics... |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
![]() ![]() Congratulations!I would do the test (I've done it at two different points during my ownership) listed on this YW link: http://www.yarisworld.com/forums/sho...ght=45k+clutch The test = post #12 on this link. Just takes a few minutes in any parking lot. Then you'll know if you can put on more miles before it needs replacement. |
#3 | |
, as I don't have that answer...but I'd still do the test I mentioned on the previous post. Good luck! |
#4 |
pics would be nice
I know someone has been into it probably Scott |
#5 |
There is a little plastic cover that you can pop on the bottom of the engine to peek into the bell housing. I didn't snap any pictures of that before I removed and separated the engine and tranny from Crashy #3. And, they are now both at James' (Jerkratt's) house.
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Clutch question. | Black_griffin6 | Performance Modifications | 6 | 04-04-2013 04:30 PM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
