Old 10-06-2013, 01:07 PM   #1
gmasood
Drives: Toyota Passo 2007
Weird issue with Immobilizer
Hi
I purchased a second hand Toyota Passo 2007 with the Smart Transponder Key having keyless entry and igniton. Basically the ignition has a plastic Key like thing protuding out and you are supposed to turn on the engine with the KeyFob in the pocket. Kind of like the push Start but with the Twist function.
The problem is that My Smart Key works fine for Keyless entry i.e I can open and close the doors with the Key in my pocket using the small black button on the door handle but once inside the car the immobolizer light continues to blink.
The only way to start the car is to take out the small mechanical key form the Transponder fob, put it in ignition and then touch my Transponder Fob with the Ignition and twist then the Car starts.
These are symptoms of the depleted battery in the Fob but that is not the case as I have replaced the battery twice. The lock/unlock buttons on the Fob also work fine. I am at my wits end as to what might be the problem.
I know its a yaris forum and apologies for posting but any help would be great.
Many Thanks.
gmasood is offline   Reply With Quote
Old 10-06-2013, 01:11 PM   #2
With the system that you have the portion of the fob that does the lock and unlock is different than the part that does the verification for the immobilizer. The transponder for the immobilizer is a small passive transponder and it may be bad or the ECM may need to be resynced with it (which would require the Toyota service tool).
Old 10-06-2013, 01:24 PM   #3
gmasood
So you are suggesting that may be the Fobs portion of the immobilizer is bad or it needs a resynch. Can i do it myself or would i have to go to Toyota for that?
Is it possible that the Immobolizer Antenna inside the car between the driver and passenger seat as per service manual is to blame or in your opinion it is the Fob.
Anything you can suggest that I might try myself. Many thanks for the quick reply.
Old 10-06-2013, 01:27 PM   #4
With the light still flashing on the car portion, I would suspect the fob portion as being the issue. You would have to go to a shop that has the official Toyota service tool to verify which piece is bad or to have the ECM and the fob resynced (or a new one synced if the existing one is bad).
Old 10-06-2013, 05:08 PM   #5
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Won't it work with a China clone ("MVCI") and Techstream?
(Both easy to obtain with some google magic...)
Old 10-06-2013, 06:35 PM   #6
Yes - Techstream is the Toyota service tool required.
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
WEIRD ISSUE WITH YARIS ! many problems at 1 time ! annn DIY / Maintenance / Service 7 06-27-2013 06:02 AM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Weird starting issue 2007 auto yaris Nask26 DIY / Maintenance / Service 11 07-28-2010 12:29 AM
Weird issue during braking xtremesniper Canada 21 06-04-2009 11:00 AM
