Old 10-08-2013, 06:58 PM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Interior lighting converted to white LED
Two things p***ed me off from the start when I got my Yaris:
1)The green LEDs in the stereo, AC controllers etc.
2)The weak interior lighting.
Now I've fixed them:
1)
I threw out the green LEDs and replaced them by white SMD-0805 ones from ebay.
It was a bit tricky because I have no tweezers, but in the end, I even managed to solder them into the AC lights
The stereo's display seems quite bright, in reality it is not bright enough to make me take it apart again and insert a damping plastic strip behind the LCD
I decided to throw in two red LEDs for the CD slot as a tribute to audi because they did not run away fast enough.
On the left you can see my still experimental selective CAN reader:
Later on, I fixed
2)
I ordered a map light and the dome light to modify them because I did not know whether this would be a success.
I took out the bulbs, soldered a bunch of SMD LEDs to a PCB and glued them in there.
Some Wiring, then it was done
For the dome light, I ordered 5360 type LED strips, put them on an aluminium sheet (energy drink can's wall :D ) and glued that to it's position, too.
No photos from that, sorry.
By using a lot of the available space, I could maximize the design power without getting thermal problems (the dome light consumes about 10W now) thus getting far more light than with the universal bulb replacements.
Yarisworld Decal -SHOW YOUR YW PRIDE!! Astroman Items for Sale by private party 235 08-21-2019 10:45 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
White OR Blue underbody LED charleschia1986 Cosmetic Modifications (Exterior/Interior) 9 12-04-2010 02:25 PM
1 DE3175 LED Bulb (White) FSANE Items for Sale by private party 3 03-26-2010 04:33 PM
