Old 10-09-2013, 09:10 AM   #1
Bigs
Drives: 2008
Anyone install a Hatch lock plunger?
I just got this 08 lift back, and love the little car.
One thing that I am struggling with is the lack of a lock plunger for the hatch. Am I missing something or is the only way to lock/unlock the hatch is w/ the key? I had an old 3 door civic before and it had a little plunger w/ an orange ring on it, so you could
1, visually verify the hatch’s locked status
2, lock the hatch before you closed it w/o the key
anyone done a mod for this, I haven’t taken it apart too much, but I did pop the little cover off and found there is something in there I can move to lock/unlock it. Just need to extend that up to the top and install a plunger of some sort.
Thanks
Bigs is offline   Reply With Quote
Old 10-09-2013, 09:18 AM   #2
It sounds like your car does not have power locks. You can add the power lock actuator from one with power locks. The other option is to switch the whole hatch lock assembly to a Scion IQ hatch switch. I have done that on with my 09, which had power locks, and my 08, which I upgraded to power locks. With my Scion IQ switch system the hatch switch is automatically disabled when the doors are locked and active when they are unlocked.
http://www.yarisworld.com/forums/showthread.php?t=39677
Old 10-09-2013, 09:24 AM   #3
Bigs
Drives: 2008
Thanks Scott,
correct, I do not have power locks
Slick system you have on yours,
Old 10-09-2013, 11:17 AM   #4
Originally Posted by Bigs View Post
Thanks Scott,
so, your best bet would be to start with adding power locks. An aftermarket kit, like the one I used on my Red one, can be had for under $150 (including keyless entry) from a place like a1-electric.com. OEM Hatch lock actuators can be found for around $50 or you can go with something like my IQ mod.
Old 10-09-2013, 02:58 PM   #5
I actually ran my echo hatch with the cover off.. as it wasn't covering much anyways. So i always simply put my hand and flip the switch to lock the hatch. LOL
If i wanted to know if the hatch was locked? Try to open it.
Old 10-09-2013, 04:52 PM   #6
Neurotic Hapi Snak
Drives: 2011 Yaris 3dr
CTScott, does your IQ actuator mod work with the factory keyless entry? Is there any other keyless entry module from another Toyota that has the remote hatch open function that could be swapped in?
Neurotic Hapi Snak is offline   Reply With Quote
Old 10-09-2013, 04:56 PM   #7
My mod would work fine with an OEM keyless entry equipped Yaris. You wouldn't have the pop functionality, since the Yaris remote doesn't have a separate hatch button, but the lock and unlock would work correctly. A module from another vehicle wouldn't help, as the Yaris Body ECU communicates with the keyless receiver and the Yaris one would not support the additional function.
Old 10-10-2013, 03:39 PM   #8
Neurotic Hapi Snak
That's too bad, would be nice to have a hatch pop button.
Old 10-10-2013, 03:57 PM   #9
I would have to do something creative, like have my module look for a double or triple press of the unlock to signal a hatch pop.
Power upgrade (pictures). W.A.S.P DIY / Maintenance / Service 91 11-15-2017 10:32 PM
Yaris Hatch Purchase warlock New YARIS Purchase Forum 7 09-02-2007 11:59 PM
Power hatch lock? paultyler_82 DIY / Maintenance / Service 5 09-08-2006 01:15 AM
