Old 10-12-2013, 12:01 PM   #1
bronsin
bronsin's Avatar
Oil Pressure Sending Unit - How To Replace?
My 2009 Yaris is leaking oil thru the oil pressure sending unit.
Is a DIY possibility?
Thanks!
Dealer wants $220.
Old 10-12-2013, 12:04 PM   #2
bronsin
bronsin's Avatar
I have an ECHO service manual. Is it similiar to that?
Where is the unit in the SM?
Thanks!
Old 10-12-2013, 01:04 PM   #3
You can grab the Yaris service manual from the Micro Image forum: http://www.microimageonline.com/foru...32-YARIS-FILES
Look at the "engine mechanical" section of the manual. It actually would be identical for the echo, but access may be a tad different.
Old 10-12-2013, 01:21 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
2nd picture in old LTNoogie's thread? 24mm deep socket.
Or page 379 of CTScott's link.
Old 10-12-2013, 01:22 PM   #5
Geoff Peace
Drives: Yaris 1.33 litre 2011
Thanks!
Dealer wants $220.
This is amazing! In over sixty years dealing with cars I have never had to replace an oil pressure switch because of a leak. Now, yours is the second one I have heard of this week! Easy to replace, unscrew the old one after disconnecting the wiring connector. There will be very little loss of oil. Clean the threads in the block and apply a few drops of threadlock to the new switch. Give it a good 'nip up' reconnect the wiring, check the oil level, start the engine, verify the warning light goes out. You have been luck really, when one of these things fails the engine can dump all its oil in less than 20 seconds. Hope this helps.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 10-12-2013, 03:55 PM   #6
bronsin
bronsin's Avatar
too late already raped by the dealer for $237
Howver he said take it up with toyotacustomer service
800 331 4331
anyenhancement possible?
Did I overfill my oil? zkay DIY / Maintenance / Service 10 06-20-2012 10:59 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
How to replace factory stereo with head unit? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 2 09-12-2006 08:14 AM
