Old 10-21-2013, 07:39 PM   #1
sparrowblue
Drives: 2012 Yaris SE
sports suspension causing this?
Ok, so I have sports suspension on my car (apparently. ..I am not very learned in mechanics and aftermarket as far as cars go. I am an audiohead, not a gearhead) could this be what is making it so hard to pull a u-turn?
sparrowblue is offline   Reply With Quote
Old 10-21-2013, 09:32 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Please expand on "so hard to" with more details. Do you get funny noises? Is it hard to turn the wheel? Does the wheel not go around enough times? Is your turn radius several lanes at full-lock? Other details, like the brand/model of your suspension parts would also help to diagnose things. Colors of parts can also be useful if the brand isn't readily visible.
Old 10-30-2013, 08:00 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Tires could be rubbing the inner fenders if too wide or wrong offset wheels.
Old 10-31-2013, 01:05 PM   #4
"sports suspension" means what? NOT ENOUGH INFO
Wide tires, wheel offsets, lowering, low tire pressure, disabled or failed power steering -- all could be reasons.
Old 11-06-2013, 01:51 AM   #5
sparrowblue
I seriously have no clue about this crap. 2012 yaris se, trd suspension. It doesn t make any noises, power steering is good. Its basically if I try to pull unto a two lane road I always have to take the far lane. There is no way I can pull into the closest lane with the wheel totally cranked. I didnt do the work and changes on the car, my knowledge is limited. Sorry for my lack of knowing anything about this. Also new, if I crank the wheel all the way when backing up, my car feels like its is still pulling in the same direction while driving for awhile.
Old 11-06-2013, 08:34 AM   #6
lol how many turns of the wheels can you make?
Old 11-06-2013, 11:14 AM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Did the car come with the TRD suspension or did you upgrade it after purchasing the car?
Did you notice a difference after the TRD parts or has it always been like this?
Old 11-06-2013, 01:25 PM   #8
sparrowblue
The suspension was aftermarket, the previous owner had it put on after buying the car from what I understand from the car history. It had the stardard SE suspension, but was changed when the car was bought.
Old 11-06-2013, 01:41 PM   #9
1.5
Form>Function
1.5's Avatar
ok so have you always noticed this issue with the car?
Are the wheels stock Yaris SE?
Old 11-07-2013, 11:33 AM   #10
mr_miles
Drives: 2013 Yaris
pics plox. I'm thinking maybe the power steering isn't functioning 100%. or one of the front strut tops is loose causing it to get stuck.
Old 01-21-2014, 05:26 PM   #11
sparrowblue
Mr. Miles, you win. Strut issue!
DC Sports 4-1 Header vs. DC Sports 4-2-1 header YenOfIrrelevent Performance Modifications 14 05-09-2012 09:40 AM
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Confort suspension for TS? shtou Yaris TS Talk 0 06-16-2011 01:27 AM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
