Old 10-25-2013, 02:19 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Little Horn For Sale
To all my YW peeps...
I've started to remove the horn system from my Yaris. It's time for me to move on to my other project car.
This shows the dual 400c compressors, the 150 psi pressure switch, the pressure gauge and the 5 gallon tank.
This is the cleaned up pic as it sits in the car now.
I've already removed the horns, manifold and the 12v solenoid from the front end of the car.
This is how it sat on the car (without the front clip)
This following clip is my test of the horn:
http://www.youtube.com/watch?v=YuKjZVsDNVY
I'm selling everything to make the kit work MINUS the 1/2 air line. That you can, and should, source new and locally.
Bottom line:
I'm selling the Nathan K3la horn set, 2 Viair 400C compressors, a 150 psi switch, a 1/2" 12v solenoid, the 5 gallon 8-port tank with the gauge...and probably a half-dozen (if not more) 1/2" quick connect fittings.
I'm selling it for $1000 LANDED in the lower 48 states. Anywhere else you will have to talk to me before I sell. I'll ship FedEx to your doorstep.
Note, a single compressor K3la kit from hornblasters sells for $1549.
If you have any questions, PM me or e-mail at sqcomp@hotmail.com
― Thomas Paine
Old 10-26-2013, 02:26 PM   #2
Mongoose7
Drives: 2007 Yaris HB
Little Horn ??
WOW !!!!!!!!!!!
Mongoose7 is offline   Reply With Quote
Old 10-26-2013, 08:09 PM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It was quite a quick project actually. When I figured out where to mount the horns, it was relatively easy to put together.
― Thomas Paine
Old 11-07-2013, 12:05 PM   #4
coheed
Drives: 08 BB LB
Man this makes me miss my International horns. Always wanted to upgrade to a K3 but never did it. I'm guessing you're not interested in payments huh? lol
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
Bungled horn install, eating fuses. CrankyOldMan DIY / Maintenance / Service 12 05-04-2013 12:05 PM
where is my horn located? 2007 3 door Suey 1958 General Yaris / Vitz Discussion 6 11-27-2011 09:57 AM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 06:01 PM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
