Old 10-28-2013, 11:34 AM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Hint: Automatic rearview mirror
Hi there,
I just picked up an automatic rearview mirror from a Corolla at the local scrap yard.
Fortunately it just has two wires to be entertained, one is Ground (white with a thin black line) and one goes to e.g. +IGN (blue/red)
For those who are curious:
-The case is hard to open, it is clipped.
The best points to start with are the short sides.
-The Pin next to the +IGN forces the mirror to be bright if 12V are applied
-The pin between the aforementioned and a second pin has about 0,8V if the mirror has been darkened. Else it's 0V
The mechanical mounting is a bit different, but with a Dremel, a screw, a small plate and a nut this should be done.
I have no Dremel in reach, so I'll have to find another way :D
Some solder pads were unpopulated on mine, it was not much work to look up the values for the resistors etc. on anoter part of the PCB where exactly the same circuitry was built up.
The existing one lights a green LED when the mirror is turned on, I've completed the other one for curiosity, and it's to light the on/off button.
the light turns on if the sensors know it's dark, but don't turn it off unless you cut the power and turn it on again if the environment is bright enough.
Powering rearview mirror. Machinist In Car Entertainment + Electronics (audio / video / alarm) 3 11-25-2012 07:00 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Replacing Rearview Mirror for Smaller One molinee Cosmetic Modifications (Exterior/Interior) 7 11-06-2008 10:56 PM
Rearview Mirror Too Big? molinee General Yaris / Vitz Discussion 23 11-06-2008 03:17 PM
