Old 11-02-2013, 06:38 PM   #1
willisjm193
Yoshi 2.0
willisjm193's Avatar
Drives: 2007 Manual Sedan
Boot behind front wheel?
I was troubleshooting something, and I found the culprit..but I don't know what the exact nomenclature is. What is this item called, or what p/n is it?
willisjm193 is offline   Reply With Quote
Old 11-02-2013, 06:58 PM   #2
That is the CV joint boot. You can replace the boot alone, but typically once they tear and dirt gets into the grease the joint gets damaged, so rather than going through the effort of pulling the axle to replace just the boot, one typically replaces the entire axle.
Old 11-02-2013, 07:00 PM   #3
willisjm193
Yoshi 2.0
Thanks for the reply, I'll search for parts!!
Old 11-02-2013, 09:31 PM   #4
Which side do you need? I have a perfect drivers side one on hand.
Old 11-03-2013, 08:11 AM   #5
willisjm193
Yoshi 2.0
I need the drivers side. Should fit the sedan too right?
Old 11-03-2013, 10:14 AM   #6
Yes. Sedan is the same. I could do $40 + shipping if you are interested.
Old 11-03-2013, 01:57 PM   #7
willisjm193
Yoshi 2.0
Definitely interested. PM sent.
Old 12-07-2013, 02:08 PM   #8
willisjm193
Yoshi 2.0
CTScott: I just got around to looking more closely at the axleshaft, as I have some free time coming up to put it in. Correct me as needed, but this is not for an ABS Yaris? I'm not seeing the reluctor ring. Is it possible to remove the ring from the old shaft and put it on the new one?
Old 12-07-2013, 06:00 PM   #9
The shaft does not have anything to do with ABS, so the same shafts work for both ABS and non.
Old 12-07-2013, 07:52 PM   #10
willisjm193
Yoshi 2.0
So where is the ABS Sensor getting the reading from, within the hub?
Old 12-07-2013, 10:53 PM   #11
Correct. The sensor is at the end of the cable and the rotor for it is within the hub.
Massive inside wheel spin + outside wheel fender rub CrankyOldMan Tracking, Racing, Auto-X Forum 8 06-04-2013 08:57 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Resistance/rubbing On Wheel During Sharp Turns? tasha Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-11-2010 04:25 PM
