Old 11-03-2013, 05:32 PM   #1
Hayabusaboy
Drives: 2007 white hatchback
Help with this braking problem.
When I brake going down a hill near my home the car feels like it downshift, it slows the car down so much that I have to accelerate to get the car to shift back to OD. I hate it, make me so mad some times that I floor board it to get going again. Is there a way to avoid this idiotic function?
Hayabusaboy is offline   Reply With Quote
Old 11-04-2013, 06:21 AM   #2
BLH
Drives: 2007 Yaris Sedan
Yes it is downshifting. Mine is the same way.
If the cold indicator is On it will not even go into top gear and shifts at different points until the transmission is warmed up.
Old 11-04-2013, 09:01 AM   #3
Does the same thing on my Civic. If you did not want it to slow down.. why would you be braking on the downhill anyways?
Old 11-04-2013, 09:16 AM   #4
Maintaining speed though a zone maybe? I have a hill in town that is a favourite speed trap for law enforcement. They sit at the bottom of a 50 kph hill, which if you coast down, by the time you hit the bottom you're doing 70 kph.
The car does downshift has soon as you tap the brake, but I do not find that I have to 'floor' it to upshift again.
Old 11-04-2013, 04:56 PM   #5
I never found it could be slowing down so much that you have to accelerate again on a downhill..
just let go the brake if it slows down too much.
It shouldn't downshift too much if you don't reach certain speed. I mean, it won't downshift the moment you step on the brake if you were doing 70kmh downhill. Probably does like around 50kmh and at that point, you probably want to let go the brake and let the engine do its thing.
braking problem yarismo DIY / Maintenance / Service 6 05-15-2013 06:06 PM
Problem with electronic door lock new-yaris-owner In Car Entertainment + Electronics (audio / video / alarm) 7 08-05-2012 05:12 PM
Problem with my car rakhan01 DIY / Maintenance / Service 8 12-03-2010 05:12 AM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
