Old 11-04-2013, 02:17 AM   #1
gillyallen
Drives: yaris
heater air flow direction control
Hi, I hope somebody knows what I am talking about.
The knob you turn to change the direction of the air flow to the floor, body and windscreen is just freely turning not clicking or moving anything.
I bought my car second-hand and didnīt realise anything was wrong until the weather changed.
It is probibly cracked or shattered inside and what I want to know is how I take off the front fascia to get to the interior control so I can manual shift the position so the air flow is towards the windscreen on a permanent basis.
Any nice guys out there that can point me in the right direction.
I don't want to get out a sledgehammer to get to it, I'm sure it must be able to slide in one direction but don't want to start pushing and pulling until I know which that is.
Any help greatfully received.
Regards Gilly
gillyallen is offline   Reply With Quote
Old 11-04-2013, 06:16 AM   #2
That is a common issue and either means that the cable snapped or just that the mechanism popped off of the back of the knob. Pull off the black vertical pieces with your fingers and then pull the AC panel off the same way and you will have access to check it out.
Old 11-04-2013, 08:07 AM   #3
gillyallen
Drives: yaris
Thank you
Thank you so much for your advice, armed with a normal knife I eased off the 2 black strips, carefully lifted the silver centre panel and managed to squeeze my finger around the white plastic thingy that had popped off and realigned it and as you said it popped right back in place. I can now see where I am going so the roafs are safe again. THANK YOU. XXXXXXXXXXXXXXXX
07 where is the air flow sensor yaris9876 DIY / Maintenance / Service 0 12-27-2012 09:02 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Recommendations on Mass Air Flow Sensor (MAF) dyslexicanaboko Performance Modifications 11 02-08-2011 10:24 PM
