Old 05-15-2006, 03:30 PM   #1
chibianh
Drives: civic
octane at high altitude.
Hi guys. quick question regarding gasoline octane levels for the us Yaris. Here where I live, the available gasoline octanes are 85, 87, and 91. The manual recommends 87 octane, but I'm assuming that's for sea level. Would running 85 be okay?
chibianh is offline   Reply With Quote
Old 05-15-2006, 04:29 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Probably. I think at higher altitudes lower octane becomes more potent, or something like that.
Either way, using an octane 2 points lower would make the car a little less peppy and maybe hurt fuel economy a little bit.
I doubt it would do any serious damage.
Colin Chapman disciple
Old 05-15-2006, 06:01 PM   #3
silverRS
Drives: 2007 Yaris RS Silver
yeah for sure, but if you run high test in it the engine will run slightly better as well as last longer.
silverRS is offline   Reply With Quote
Old 05-15-2006, 06:12 PM   #4
corey415
Drives: 95 Integra
That hasn't been proven. I have read multiple sources that say adding higher octane when not required is simply throwing money away.
The Yaris motor requires 87 octane. Putting in 85 octane won't damage the motor; I am pretty sure it has a knock sensor. The motor will have to retard it's timing so that means you will get less performance and perhaps lower fuel economy.
corey415 is offline   Reply With Quote
Old 05-15-2006, 06:26 PM   #5
chibianh
Drives: civic
THat's understood, but like I mentioned in my original post, we have 85, 87, and 91 here at 6000ft above sea level. 87 octane is lowest elsewhere I've traveled. I'm just wondering if 85 octane @ 6000ft = 87 octane @ sea level. :)
Old 05-16-2006, 03:30 AM   #6
why?
why?'s Avatar
Drives: Yaris LB
All tests done the manufacturers use 93 octane fuel. There is a reason for that.
I do not know if it will increase engine life, but higher octane fuel will give a slight bump in power and fuel economy. The emphasis should be on slight.
Old 05-16-2006, 10:48 AM   #7
Uglyboyed
Uglyboyed's Avatar
Drives: 07 Yaris Sedan S Flint Mica
Send a message via AIM to Uglyboyed Send a message via Yahoo to Uglyboyed
i usually use 91 since here in florida its the middle. we got 87,91, and 93. but hey if i can use 87. it"ll be alot better for me. but on the other hand i get better milage with the higher octane. maybe like 2-3 miles a gallon.
Uglyboyed is offline   Reply With Quote
Old 05-16-2006, 10:55 AM   #8
chibianh
Drives: civic
thanks guys... i think I'll be using the middle one... 87 octane. :)
Old 05-16-2006, 11:22 AM   #9
Ziv
It's all about VVTI
Ziv's Avatar
Drives: Yaris 5Dr LE White
I believe we had a page about Octane, well, not specifically at high altitude. but I believe that would be helpful also, please check the pages we have posted probably months ago.
Ziv on Vitz '06.
Ziv is offline   Reply With Quote
Old 05-16-2006, 11:36 AM   #10
yariman
Speed Wrenchin'
yariman's Avatar
Drives: 2006 Yaris 3 door, Bayou Blue
Most fuel refiners blend their fuels for specific areas such as high altitudes. They blend to compensate for the decrease in oxygen etc. If you use your local fuel, the 87 octane should work just fine.
Quench my thirst with gasoline
yariman is offline   Reply With Quote
Old 05-16-2006, 12:47 PM   #11
fearturtle44
Drives: S Flint Mica
If the car says to use 87 octane and you use a higher octane, your are wasting your money. Higher octane does nothing to help.
If your car says to use high test, then use high test as the engine was manufactured to run the higher octane.
Kevin
fearturtle44 is offline   Reply With Quote
What type of octane I should use??? krakkhenz DIY / Maintenance / Service 95 08-23-2006 05:53 PM
