Old 11-09-2013, 04:19 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Drivers door window controls coming loose
08 Sedan..When i use one of the controls on the drivers door arm rest the whole unit seems to be coming loose, when i press down on a window control all the control switches move about a half inch, How do i get the piece of plastic off to see whats come loose underneath.Or is this best left to the dealer to fix?
Looks almost identical to this unit.
Have Yaris will travel..
Old 11-09-2013, 06:49 AM   #2
The whole assembly can be pulled off. There are plastic clips that keep it in place.
Old 11-09-2013, 10:07 AM   #3
jambo101
jambo101's Avatar
I get nervous with plastic clips as they have a tendency to break making reassembly impossible..
Old 11-09-2013, 10:12 AM   #4
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Apart from the instrument cluster, I did not break any of the non replaceable clips up to now ;)
Old 11-09-2013, 01:38 PM   #5
Understood. The ones for the window controls are the type that don't tend to break, but the fact that yours is not latched in place kind of says that something under there is already broken.
Old 11-10-2013, 07:45 AM   #6
jambo101
jambo101's Avatar
Took it apart no problems. and discovered the plastic shaft that the power unit screws into is broken. I guess my options are an entire new plastic molding or just live with somewhat loose buttons for window operation.
Wonder what one of those plastic pieces cost.
Old 11-10-2013, 08:10 AM   #7
dj92
Embracing Curves
dj92's Avatar
How is the plastic molding marked? (too lazy to take mine apart now :P )
If it's PE or PP, you could take a lighter or soldering iron and try to weld it together again, if it's ABS or PS you could put some polystyrene (Styropor) into acetone and glue it together with the goo that results (acutally it's even cold welding).
This should be quite strong, because unlike normal glue (e.g. Pattex), the joint has no real foreign materials which let it break apart easily :)
And when I tried it, it did not stick to my fingers!
Old 11-11-2013, 04:16 AM   #8
jambo101
jambo101's Avatar
The piece is all plastic with a female column just ahead of the window lock button built in to accommodate the screw that comes up through the power unit and locks everything in place.
I need a new plastic control module cover like the yaris version of the one pictured
http://i00.i.aliimg.com/photo/v0/424...r_COOLBEAR.jpg
And the worst drivers in America live in..... KCALB SIRAY Off-topic / Other Cars / Everything else Discussions 12 05-22-2009 08:55 PM
