Old 11-12-2013, 09:28 AM   #1
kropekoi
Drives: vios 1.3J
Unhappy RPM low and rough idle
Hi All,
I just had my vios (Yaris Sedan) serviced and I've already changed the air filter and cleaned the MAF sensor myselft. However, the RPM of the car is getting lower than 500 when I turn the AC on. On a cold start the car is idling roughly at 1k+ then it gets lower to 800 and it stays there, but when I turn on the AC it gets lower to 400 then the car starts to shake including the stick shift, and when the aux fan starts to run the RPM goes up to 700 then after a second it goes down again, and the aux fan turns off. It does this up and down rhythm for while (more than 5minutes) but when I drive and stops, it does the same thing. It did died on me a couple of times though.
But when I drive for more than 20minutes and I stop, it goes back to normal...
I need help from you Guru's, Masters, everybody! This is very annoying!!!!
TIA!
kropekoi is offline   Reply With Quote
Old 11-12-2013, 09:30 AM   #2
kropekoi
Drives: vios 1.3J
What do I need to do?
Someone told me to replace the Ignition Coil (which is expensive per piece), someone also told me to check the Idle Air Control Valve (which I have no idea if I can clean this or where I can locate this)
Old 11-12-2013, 10:17 AM   #3
I would try cleaning the throttle body, which contains the IAC valve. Carbon deposits in the throttle body can cause this behavior.
Old 11-12-2013, 06:15 PM   #4
kropekoi
Drives: vios 1.3J
do you happen to know on how to clean the IAC valve?
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 02:37 AM
3rd gen 1zz tb swap mr_miles DIY / Maintenance / Service 26 05-01-2013 09:20 AM
Need advice/ help for rough idle lilj4321 DIY / Maintenance / Service 2 08-28-2012 03:39 PM
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 02:46 PM
