Old 11-14-2013, 04:07 PM   #1
nineth84
Drives: 2008 yaris 4dr
Red face Driver Side Seat Wont stay in place
Hello,
I sorta new to all of this. i have a 2008 yaris 4dr and have come into a particular issue. as the title says; the driver seat wont stay in place and its quite dangerous to drive like that. it just slides back when i press the gas and forward when braking. the release bar is loose, just moves up and down. i didnt see anything under the seat that fell off. im assuming a spring or something myabe have fallen off place. even when the lever is pressed down it still wont lock. is there a fix for this or should i just scavenge a junk yard for a new seat? i was quote $2000!!!! for the repair. im not paying that. snows balls in hell!
nineth84 is offline   Reply With Quote
Old 11-14-2013, 04:56 PM   #2
Toyota considers that assembly to be part of the entire seat frame (and then the rails are two separate additional parts), so your best bet is a junkyard.
Below is a picture of a set of seat rails that I recently sold. The left one is the drivers side. The entire assembly is bolted to the bottom of the seat with a few bolts. You could try taking yours apart to see if there is something obvious with the latching mechanism.
Old 11-14-2013, 05:14 PM   #3
Yeah, pop the seat out. It's very easy with only 4 E10 torx bolts holding it in. Once you can see the underside, being such a simple mechanism, it should be easy to diagnose the problem.
Old 11-15-2013, 12:53 PM   #4
nineth84
ok cool thank you guys. ill go ahead and check that out.
Drivers Side Seat Belt Won't Retract redyaris DIY / Maintenance / Service 8 08-07-2014 10:37 AM
seat upgrade needed-options? OTB Cosmetic Modifications (Exterior/Interior) 8 12-12-2012 09:01 PM
se driver seat? b20vteg Third Gen Yaris General Discussion 1 08-10-2012 07:37 AM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
Rockland Toyota's Scion Revolution 4.0 phyre76 NY / NJ/ CT / PA 70 08-11-2010 05:20 AM
