Old 11-21-2013, 03:20 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
retro fit project got question? help!
im bored and need to do a project to keep me busy and i chose "PROJECT RETROFIT" retro fitting a projector lense specifically using morimoto mini h1 since i gathered this wont require cutting my stock lense.
heres my question.
* want to blackened the housing DO I need to sand it or can i just paint over it? would it stick..and can i use any regular matte black spray paint..
* and what to use to seal the headlight housing back?
thanks folks!!
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 11-22-2013, 10:44 AM   #2
jcboy
Drives: Sedan 07
heres my question.
--better use hi-temp paint as the headlight can get pretty hot, although TBH i haven't heard of any issues with regular paint
any silicon-based sealant should work, but of course you should have not removed the OEM sealant that you melted to open the headlight, so first reheat your existing sealant that is still there and add the silicon just for insurance
thanks folks!!
Old 11-22-2013, 04:28 PM   #3
marcus
toyota
marcus's Avatar
cool thanks.. project on the go...im excited...
Old 11-22-2013, 05:31 PM   #4
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I have those same projectors. Maybe for the 3 door you won't have to cut, but I had to do a good bit of cutting on my sedan ones. I had to open the back of the housing up a little to get the wiring through, then I had to cut the blinker housing and the plastic bit that attaches directly to the lens. I filled the hole in with JB Weld plastic putty stuff.
I used Krylon Fusion satin black paint for mine. You'll want to sand the chrome stuff off, otherwise the paint won't stick well.
I used the 3m sealant they use around windshields for sealing the lights back up. I've had 0 fogging. Those projectors are awesome, you picked well :) Enjoy them!
Here's some of the cutting I had to do.
Old 11-22-2013, 05:45 PM   #5
marcus
toyota
marcus's Avatar
nice.. is that the mini gatling gun shroud or the 2.0.. and what size led did you use??
Old 11-25-2013, 10:27 AM   #6
47_MasoN_47
Yep that's a mini gatling gun. I'm pretty sure it's a 60mm.
Old 11-25-2013, 12:03 PM   #7
marcus
toyota
marcus's Avatar
nice..im going for the regular size gatling gun shroud..just looking and waiting for some promo..
Old 11-25-2013, 05:48 PM   #8
47_MasoN_47
You getting yours from TRS or a dealer in Canada? I talked to TRS on the phone a good bit before buying my stuff. Good guys to work with. They're just about 4 hours away from me. They have a lot of helpful videos on their youtube channel too.
Old 11-28-2013, 12:45 PM   #9
marcus
toyota
marcus's Avatar
Ordered it last night...hope I get it before Xmas..:)
Old 12-10-2013, 01:19 PM   #10
marcus
toyota
marcus's Avatar
package recieved... now where to start...
Old 12-10-2013, 02:31 PM   #11
47_MasoN_47
Be prepared for a lot of work :P
Something that will save you a lot of time is go to ahead and adjust the projectors before even doing anything with the lens. Make your cuts so that the projectors fit into the housing without any binding or pressure points, then go ahead and install them in the car. Get them adjusted where you want, then do the cutting on the lens. I cut my lens first and ended up cutting a whole lot more than I would have had to if I'd adjusted them first.
Old 12-10-2013, 03:19 PM   #12
marcus
toyota
marcus's Avatar
i got the hatch version i dont think i need to do any cutting at all...unlike the sedan...unless im missing something?
Old 12-10-2013, 03:44 PM   #13
47_MasoN_47
Maybe not, but I'd be pretty surprised.
Old 12-18-2013, 11:14 AM   #14
marcus
toyota
marcus's Avatar
now im worried...but i did start painting the shrouds..
Old 12-19-2013, 06:51 PM   #15
bestyaris
Drives: Polar White 4 Dr
anybody tried to paint reflecter with PlastiDip?
good idea? bad idea?
2007 Yaris Base Sedan
bestyaris is offline   Reply With Quote
Old 12-21-2013, 03:48 AM   #16
Kickyaris09
Drives: 09 yaris blazin blue
I would say bad idea...don't want a goey mess in there when the lights heat up.
Kickyaris09 is offline   Reply With Quote
Old 12-30-2013, 03:18 PM   #17
jetaimejsc
jetaimejsc's Avatar
Drives: Yaris Hatchback
any pics of update marcus?
jetaimejsc is offline   Reply With Quote
Old 12-31-2013, 03:37 PM   #18
marcus
toyota
marcus's Avatar
its done i just have to shrink the photos so i can upload it..hopefully tonight,..
Still no VIN for Yaris, reconsidering Fit cathycnm New YARIS Purchase Forum 40 10-07-2013 10:39 PM
post for my project Andikilzz Cosmetic Modifications (Exterior/Interior) 36 01-28-2013 02:30 PM
Roof rack question / Thule fit kit or Yakima drilled option dasnake DIY / Maintenance / Service 20 03-22-2012 11:43 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
