Old 11-23-2013, 01:08 PM   #1
shangapol
Drives: Yaris Sedan
Exclamation Maintenance at 50000 mi
Hello folks,
I'm from Latin America and I need to know What I need to do when I reach 50k mi (80000kms) with my 2007 Yaris Sedan? what I need to check or change in my car?
Please help me with this, I love my car and I want it perfect...
Thanks dudes...
shangapol is offline   Reply With Quote
Old 11-26-2013, 10:27 AM   #2
esse10
Drives: 2009 yaris 2 door
maintenance
well, aside form the regular maintenance like oil and air filter you might want to remove the spark plugs and check the gap, put anti-seize on the threads and put back in. Also check the control arm bolts that are a common problem of rusting . There is a diy thread around here just do a search. I took mine out a month ago and they were still in good condition and hardly any rust on the bolts.
Old 11-26-2013, 11:14 AM   #3
You shouldn't gap the iridium plugs.
Old 11-26-2013, 11:28 AM   #4
shangapol
Drives: Yaris Sedan
Talking
Perfect...
Well I have K&N air filter, I will clean my filter and put it again, so iridium plugs are better than OEM plugs??.
Thanks again dudes...
Best regards...
Old 11-26-2013, 03:46 PM   #5
harda toenail
Drives: Want a yaris
Just give it a good bath and make sure the oil changes are regular.
harda toenail is offline   Reply With Quote
Old 11-28-2013, 04:37 PM   #6
shangapol
Drives: Yaris Sedan
Smile
Of course, I have another question about the motor oil:
20w50 Valvoline Semi-Sintec
15w40 Shell Helix Semi-Sintec
Or
Castrol 20w50 Magnatec Semi-Sintec
Which of this three oil are better? Remember is for my 1.5 vvt-i Yaris Sedan with 50K miles (80k kms).
Thanks dudes... Happy thanksgiving to all ToyoFans!!
Old 11-29-2013, 11:35 AM   #7
esse10
oil
Or
IMO,
Depends where you live I believe. If where you live is mostly cold and stays below freezing for weeks on end ......ie Canada than synthetic oils will be best to use. If you live in a place where it's mostly warm and it only freezes once or twice a year but it's mostly above freezing temperatures year round than regular dino oil will be fine. I use Valvoline 5w30 regular dino oil
Old 11-29-2013, 04:17 PM   #8
Or
jesus.. these oil are way too thick for the little engine.
better go back to 5w30.
Old 01-07-2014, 09:01 PM   #9
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Yes,the stated oil is too "heavy"....20w----. 5w-30,yes.
frog13 is offline   Reply With Quote
80k, kms, maintenance, miles, yaris 2007
Maintenance schedule Connoisseur_of_fine_cars DIY / Maintenance / Service 9 10-05-2011 07:46 PM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
60K Mile Maintenance Pattycake DIY / Maintenance / Service 20 11-17-2009 02:34 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
