Old 12-02-2013, 03:47 PM   #1
pandus13
Drives: 5dr Sedan
Question 2008 sedan, AT, 28k miles. maintenance on time interval?
Hi ,
first owner on 2008 yaris sedan, AT, now at 28k miles, midwest.
had the oil changed at 4 months, changed at 6 months last year.
still on original tires, ATF, coolant, braking fluid, brakes.
anything I should do based on time interval?
thank you
pandus13
pandus13 is offline   Reply With Quote
Old 12-02-2013, 04:17 PM   #2
You're basically good. Might want to check/replace cabin air filter located behind the glove box.
Here is a link to the 'recommended' maintenance schedule I got with mine. Keep in mind that mileage intervals are in kms, so you'll have to convert to miles
http://www.yarisworld.com/forums/sho...01&postcount=2
Old 12-02-2013, 04:29 PM   #3
pandus13
Drives: 5dr Sedan
oh cabin air filter, i forgot, got some made from a regular house filter. i changed at least 4-5 times.....
engine air filter replaced twice.
and oil almost never changes color (during 3-4 months/change)....
Old 12-02-2013, 04:47 PM   #4
that's crazy amount of oil change for such little mileage.
Old 12-02-2013, 05:02 PM   #5
pandus13
Drives: 5dr Sedan
regarding the # of oil changes:
at first it was a city short tripper.(2008-2011) so not really much time to get up to parameters
than i changed the interval to every 6 months.got also a little bit longer drive so oil gets hot....
oil used regular or semi-synthetic.
used only dealer only changes/filters than DIY with Toyota original oil filter bought from dealer (receipt kept just in case...)
Old 12-03-2013, 08:46 AM   #6
eitherway... i think oil change at 3-4 months is overkill.
coolant change is 8 years 100k miles if i remember right.
check your tires for cracks, if you see cracks, then it's time to change your tires, even if they still have deep threads.
http://www.tirerack.com/tires/tirete....jsp?techid=30
Rines 15 Yaris Sedan 2008 Marko_ec Central and South America 4 12-15-2008 03:02 PM
2008 Toyota Yaris Sedan phenoyz Cars for Sale by private party 3 11-27-2008 07:24 PM
FYI: UOA Toyota Factory Fill, 1100 miles, Toyota Yaris Sedan craigq DIY / Maintenance / Service 2 06-16-2007 11:22 AM
