Old 12-09-2013, 10:09 PM   #1
d3310n
Drives: black titty
insurance is buying me a new wheel and tire stup. heres what im going with.
the rims http://www.ebay.com/itm/15-White-Kud...0c28cf&vxp=mtr
with some ebay toyo proxres t1r tires at 185/55r15
im on micro image springs, so ill be running 20 offset and a mild tire stretch. prob going to have to roll the fenders, maybe add a little camber. thoughts?
d3310n is offline   Reply With Quote
Old 12-10-2013, 12:42 AM   #2
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I run 205/50/R16 on NF210s, I had to do a slight fender roll on the rear, but other than that I don't really have any problems. It scrubs some at full lock to the left, but not enough to bother anything. I'd just try to run it and see how it does.
Old 12-10-2013, 01:13 AM   #3
d3310n
Drives: black titty
what about hard cornering any rub
Old 12-10-2013, 09:37 AM   #4
47_MasoN_47
Nope, I can load the trunk so full that it's riding the bump stops and it still doesn't rub.
Old 12-10-2013, 09:51 AM   #5
d3310n
Drives: black titty
sweet
Old 12-10-2013, 12:50 PM   #6
Your tires will be right at the fenders with 15x7, ET20. I can't remember how low the MI springs go, but I would highly suggest rolling the rear fenders. You may start cutting into the tires.
Those are 17x7.5, ET28, so about 2mm more outward than the rims you will be getting. The tires weren't stretched, but that pic was driving for 2-3 miles with a total of four people in the car. I'm on S.Tech's, so I think I'm lower than you, but that's what happened without rolled fenders in the rear.
Old 12-10-2013, 02:37 PM   #7
d3310n
Drives: black titty
definitley plan on it. im actually more worried at the front, roll those too and maybe a stiffer front swaybar will save me?
Old 12-10-2013, 03:48 PM   #8
47_MasoN_47
I didn't have to roll the fronts on mine, but the rears I did have to roll just a little bit. That section in Kaotic's picture rubbed on mine when I first went to the 205s. I just jacked the car up a little bit and used a baseball bat to roll that lip up.
Old 12-10-2013, 07:06 PM   #9
d3310n
Drives: black titty
if anyone is intrested in my old wheels and tires pm me
Question on Wheel and Tire soup1207 DIY / Maintenance / Service 1 05-24-2013 10:11 AM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
