Old 12-12-2013, 04:31 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
OIL CATCH CAN D-I-Y
SIMOTA OIL CATCH CAN INSTALL
I put this on MicroImage from my phone. most of us have log-ins over there to view the images....let me know if I need to port this over to here instead of linking to it....
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 12-12-2013, 05:02 PM   #2
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Looks good. I tried a few different catch cans, and could not get my car to run without throwing a CEL. I did not try the Simota. Hope yours works well.
goliath1812 is offline   Reply With Quote
Old 12-12-2013, 05:12 PM   #3
Shroomster
Shroomster's Avatar
Hopefully....
Old 12-12-2013, 05:12 PM   #4
Really nicely done, very clean.
Old 12-14-2013, 02:24 PM   #5
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
clean!
MyzticZ3r0 is offline   Reply With Quote
Old 12-14-2013, 10:32 PM   #6
Shroomster
Shroomster's Avatar
One of two is doing fine. The one on the 2012 is flawless. Mine, the 2014, I keep getting p0171 for lean. Do I have a dud, or does a catch can reading change the vacuum readings that much?
Old 12-14-2013, 10:44 PM   #7
You must have a leak. If everything is sealed it should not have an effect like that.
Old 12-15-2013, 06:59 AM   #8
Shroomster
Shroomster's Avatar
Yeah, is weird as everything is tight. I don't have a smoke machine to check for leaks, but I still suspect that the pcv nipple being able to slip out of the silicone tube even with the hose clamp tightened is the culprit, yet I now have two clamps on it and a spacer between the tube and clamp.... Maybe a smaller diameter tube is in order....
Old 12-15-2013, 06:06 PM   #9
Shroomster
Shroomster's Avatar
I'm hoping I found the leak. The breather tube from cc to intake had oil seepage around large nipple on air intake, it was clean yesterday. Where there's fluid there's going to be an air leak....
Old 12-15-2013, 07:54 PM   #10
Shroomster
Shroomster's Avatar
No go still.... waiting on wife to bring home PTFE tape... Going to remove inlet & outlet ports and apply the tape, also to drain plug.... Here's to going it works....
Old 12-15-2013, 09:42 PM   #11
How is the can constructed? Does it have an inner plastic container or is the the sight window bonded to the aluminum?
Old 12-15-2013, 10:33 PM   #12
Shroomster
Shroomster's Avatar
Looks to be sealed, dual windows on aluminum.....
Old 12-15-2013, 10:36 PM   #13
That might be worth testing as well. Stick a finger over the two fittings and hold it under water and look for bubbles.
Old 12-16-2013, 07:13 AM   #14
Shroomster
Shroomster's Avatar
Yeah, testing of the unit will come today.... I added PTFE to the three ports... The code hasn't popped yet, but it is showing as pending if I'm reading the code reader correctly.
Old 12-22-2013, 01:11 PM   #15
Shroomster
Shroomster's Avatar
Alright, I found the leak.... It's coming from the lower shiny end cap where it mates to the main cylinder.... I'll post a pic in a few....
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
