Old 12-28-2013, 11:31 AM   #1
tenchsama
Drives: 2009 Yaris sedan black
Debris in heater box, water under dashboard
Hi all,
2009 Toyota Yaris sedan, 76000 miles -
During the summer I began to get a water leak under the passenger side dash when running A/C, sloshing water sound when making turns. Turned out there was a build up of debris (leaves, pine needles) in the heater box. Pinching, blowing out drainage tube no help. Had to have dashboard pulled and box cleaned out ($1000 mostly labor) - not covered by warranty or considered a defect - of course.
Ive heard that Toyota is aware of the problem and there is a replacement cowl (under windshield wiper?) designed to prevent debris from getting into engine compartment/heater box but can't get any information on this...
Has anyone else heard about a replacement cowl?
Any ideas on who to contact - no response from Toyota yet.
Thanks
tenchsama is offline   Reply With Quote
Old 12-28-2013, 01:39 PM   #2
Originally Posted by tenchsama View Post
Hi all,
Thanks
The replacement cowl was just for 07. The 08+ Yaris have had the newer cowl. The real key though is using a filter in the cabin air filter slot behind the glove box. That will prevent all large particles from entering the air box.
Old 12-28-2013, 07:32 PM   #3
SecondYaris
Drives: 2013 Yaris HB
I had the same problem when I owned my first Yaris 2007, took it to the dealer since it was still under warranty, they opened the blower box and emptied a ton of leaves stuck inside, also there was a clear rubber hose under the passenger side firewall that is suppose to drain this it, also gets plugged up. I don't think I was the first one with that problem.
The fix that I never got around to is put some sort of a screen cover over or under the windshield cowl intake, right under the wipers. I now have a 2013 Yaris, guess what it already has a screen cover under the cowl, so I hope this will prevent that problem.
SecondYaris is offline   Reply With Quote
heater, water leak
Dual 8’’ Cargo Floor Sub Box Build Ataristyle In Car Entertainment + Electronics (audio / video / alarm) 18 03-23-2016 01:27 AM
heater not working water coolant level drops Mike Hancock DIY / Maintenance / Service 4 11-03-2011 02:14 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
Sub Box Desgin talnlnky In Car Entertainment + Electronics (audio / video / alarm) 5 08-23-2009 01:45 AM
