Old 12-31-2013, 02:07 PM   #1
mtshum
mtshum's Avatar
Drives: Echo RS
Check engine code P0138
My check engine light on, error code P0138.
check engine light was off this morning, is it still ok to drive?
If need to replace it, is it hard?
My car is 2005 Echo
Thanks.
mtshum is offline   Reply With Quote
Old 12-31-2013, 02:35 PM   #2
P0138 is an error for the second O2 sensor (the one that is after the catalytic converter). It is not too bad to replace, as long as you can get under the car. The other end plugs into a connector under the center console near the gas pedal.
Old 12-31-2013, 03:55 PM   #3
LuisPRTRD
Angry Bird
LuisPRTRD's Avatar
Drives: yaris sedan
^+1
LuisPRTRD is offline   Reply With Quote
Old 12-31-2013, 08:33 PM   #4
mtshum
mtshum's Avatar
Drives: Echo RS
Thanks, CTScott, do I need to remove the passenger seat to remove the second O2 sensor?
Old 01-01-2014, 12:42 AM   #5
No. It comes through the floor right under the center of the dash. You will probably have to pull the AC controls to get to it.
Old 01-02-2014, 10:07 PM   #6
mtshum
mtshum's Avatar
Drives: Echo RS
Hi CTScott,
My check engine light was off this two day, do I still need to change the rear O2 sensor?
also, my car is only 77,000km. is it too early for the sensor to be failed?
Thanks
Old 01-02-2014, 10:58 PM   #7
Hi CTScott,
Thanks
You could wait and see if the code comes back. 77k Km does seem early, but there are a few things, including bad fuel that could foul one prematurely.
Old 02-01-2014, 12:32 PM   #8
mtshum
mtshum's Avatar
Drives: Echo RS
An update:
The code came back again, so finally replaced the second O2 sensor.
Just discover the left cv boot cracked, need to replace too.. ~~
Old 12-18-2015, 07:33 AM   #9
Lemayilleur
Drives: Yaris 2007
Going to bump this one old thread and ask: Any harm in driving the car with P0138 for a longer period? My car seem to work fine and MPG is average. Can I wait it out or should I not?
Thanks!
Lemayilleur is offline   Reply With Quote
Old 12-18-2015, 09:46 PM   #10
Thanks!
No real harm in doing so. The purpose of the sensor is to show that the cat is still in place and that its catalyst is still good.
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
ODB2 Check engine code reader Arkhangel Performance Modifications 11 02-25-2009 04:13 AM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
