Old 01-12-2014, 12:51 PM   #1
waxaddict
Drives: yaris 5 door 2002
Unhappy Yaris won't start :/
Hi guys, hoping someone can help me with this as I'm clueless with cars.
I recently let my dad use my 2002 Yaris, manual, for a month while I was away. Whether its coincidence or he did something I don't know, but in the 3 weeks since it would turn over for a good few seconds before starting up.
Never had any problems before, and he said its just the weather, but it would happen mostly once the car had run for a bit. Start immediately, pop to the shop, then when starting again it would take a few seconds.
Today I started it and it jumped straight on but then instantly just cut out.
I turned the key again and it just kinda spins and just gives a long whirring sound. Nothing is kinda kicking in or trying to, its just a whirrrrrr.
Sods law, I'm supposed to be selling her later this week and now I get my first big problem.
Any ideas? Things I can check before I take her to a shop and get fleeced?
Cheers.
waxaddict is offline   Reply With Quote
Old 01-12-2014, 02:27 PM   #2
With the loud whirrr, is the engine turning or is that just coming from the starter spinning, but not turning the engine?
Old 01-12-2014, 02:44 PM   #3
waxaddict
I'm not sure, how can I check?
Its not a really loud sound, and its just constantly the same, just like something is spinning, there's no like grunty sounds like the engine kicking in, and its not like brrrrrrrrbrrrrrrrbrrrrrrrr, just brrrrrrrrrrrrrrrr if that makes any sense! I'm pretty clueless.
It's parked at a friends at the moment, tomorrow I'm gonna try and bump start it if possible and get it home.
Old 01-12-2014, 03:22 PM   #4
Open the hood and have someone watch while you crank. If the belt spins, then the engine is turning, but not firing. If it does not, then the starter is not engaging.
Old 01-12-2014, 03:24 PM   #5
waxaddict
Ok, cheers. I'll give it a go in the morning and report back.
Old 01-13-2014, 04:07 AM   #6
waxaddict
Turning the key, the belt here turns, albeit slowly.
http://i.imgur.com/ej0rpBB.jpg
Old 01-13-2014, 04:55 AM   #7
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Flat battery or old starter.
Mine acts up when it's a hot day it'll fire up but hesitates. What could it be?
Old 01-13-2014, 06:41 AM   #8
Most likely it is that the battery is too low. Try charging or jumping it.
Old 01-13-2014, 07:10 AM   #9
waxaddict
OK I'll give it a bump start in a bit.
Am I right in thinking that if it bumps alright then its definitely a battery issue?
Old 01-13-2014, 07:21 AM   #10
Yes. Battery or possibly alternator, but if it has been doing more sitting than driving, then it is more likely the battery. Over here, most auto parts stores have a device that they can hook up to the car to test the battery/alternator and will do so for free. If you have access to a multimeter a simple test is to measure the battery voltage before and after starting the vehicle. It will typically run between 11 and 12.5 volts before starting and will go up to 13.6 to 14.1 volts once running.
Old 01-13-2014, 10:34 AM   #11
waxaddict
OK, managed to jump start it. Drove around for 20 mins OK, chugged a bit at first but was normal then
Parked up at home, turned off, waited a few seconds and started her up again, no problem.
The real test is in the morning, but otherwise it seems like a definite battery issue? Not the starter motor?
Old 01-13-2014, 10:57 AM   #12
Correct.
Old 01-13-2014, 10:59 AM   #13
waxaddict
Lovely, cheers for the help!
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
