Old 01-17-2014, 01:51 AM   #1
BigGreezy75
Drives: 2012 Toyoya Yaris Sedan
Help with AUX in 2012 Yaris Sedan
How do I play music from my mp3 player/phone in the 2012 Yaris Sedan? I see the button bythe radio that says Aux/ipod and a port that says ipod. However i dont recognize what kind of port it is. And I dont see an Aux cable port anywhere. So Im not sure how to connect my phone/mp3 player. Can anybody help? Thanks in advance!
BigGreezy75 is offline   Reply With Quote
Old 01-17-2014, 06:29 AM   #2
Does the connector look like this:
Old 01-17-2014, 09:52 AM   #3
BigGreezy75
Yes I think thats it. Thats what the port looks like, but I dont have that cable. Is that the only way? Where can i get that kind of cable and whats it called?
Old 01-17-2014, 12:03 PM   #4
You need the Yaris Ipod connectivity kit PT545-00082. Toyota charges over $200 for it, but I see some on ebay for under $50.
Old 01-17-2014, 01:53 PM   #5
BigGreezy75
Ok does that kit only work with apple products? Or is it compatible with other mp3 players or android devices?
Old 01-17-2014, 02:46 PM   #6
JustPassinThru
Drives: No more Yaris
The patch-cord jack is in the glove-box...it's in the frame to the glove-box door, at the top.
You have to get a patch-cord that has an angled-off jack, so you can close it.
It's a much-poorer design than the 2009 which had the jack socket in the console.
JustPassinThru is offline   Reply With Quote
Old 01-17-2014, 04:07 PM   #7
The O.P.'s 2012 Sedan is not the same as your 2012 liftback.
The OEM ipod connectivity kit is just for Apple devices (and has the 29 pin connector, so if you have one with the lightening connector you would need to use the adapter).
Can you post a pic of what your headunit looks like? If it is the one I am thinking it is, then your other option is to add an AUX jack (which theoretically the wiring should be present for) which give you a 1/8" headphone jack input, so you can use a male to male cable to connect any device with a headphone jack.
Old 01-18-2014, 09:14 PM   #8
Kar98
Drives: 2011 Scion tC
Still got one of those cables sitting on my desk at work.
Old 05-04-2014, 11:21 AM   #9
abarson
Drives: 2010 Yaris Sedaon
If you have a non-Apple MP3 player, all you need is a cord with 3.5mm stereo connectors. The AUX port is inside the pocket on the right side of the center console.
The goofy IPod connector next to the hand brake carries control signals to the HU, but only from Apple products and using the proprietary adaptor.
abarson is offline   Reply With Quote
2012 Yaris Sedan Dorkinheimer Third Gen Yaris General Discussion 34 03-31-2013 06:37 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
