#1 |
![]() Drives: 2009 hatch Join Date: May 2013
Low idle under load
Hello all,
Question my 2009's idle bogs to the point of almost stalling while the lights are on and the heater is running should I just set the idle screw in the throttle body a bit or unplug the battery to reset the ECU, or something else? Thanks! |
Did you by any chance disconnect or run the battery down recently? If so, then you it is likely due to the throttle position zero being off because of carbon deposits. If that is the case, cleaning the throttle body and then resetting the ECM will improve it.
#3 |
Just got the car used actually so I'm not sure, I'll give those a shot though thanks!
#4 |
Just a quick note resetting the ECM is done by DCin the battery for a few right?
#5 |
Correct
#6 |
Thanks again! man I love these forums..installed a tac, painted my badges and found people doing a group drive in my soon to be state..
#7 |
ECM reset and a little nudge on the idle screw and all is well thanks again CT!
![]() Yaris Japan's "Mini".. |
#8 |
Excellent! And, by the way, welcome to the forum.
| Low RPM when Idle | Betrivent | DIY / Maintenance / Service | 12 | 03-03-2013 06:55 PM |
| Idle low | yariseggvvti | DIY / Maintenance / Service | 14 | 12-17-2012 12:04 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
