Old 01-24-2014, 06:30 AM   #1
jaimico
Drives: yaris advance
BACK UP LIGHTS PROBLEMS
Hello guys, I just notice that my BACK UP lights are not working properly, it does lights up when I put the gear on reverse, but some times turns off, is like something with the switch is loose.
Where is the switch for it?
My light of temperatura cluster also for the a/c when off some time ago, I installed a new bulb but nothing happend, si it has to be something else, please advise.
jaimico is offline   Reply With Quote
Old 01-24-2014, 08:21 AM   #2
What year is Yaris and is it an automatic or manual transmission?
Old 01-24-2014, 12:02 PM   #3
jaimico
2008, sedan, manual
Old 01-24-2014, 12:44 PM   #4
Originally Posted by jaimico View Post
2008, sedan, manual
OK. The back-up light switch is located on the top of the tranny. You will need to move the battery out of the way to get at it.
To do a quick and easy test to see if it is actually the problem, you could jump the red wire in pin 3 of connector CA1 to a +12V power source. If the lights come on when you do that, then you know that either the back-up switch is bad or its connector is corroded.
Old 01-24-2014, 05:03 PM   #5
jaimico
Thanks a lot, I will check on it!
Old 01-26-2014, 10:55 AM   #6
jaimico
Yes the lights are ok, so it's got to be the switch or the plug, where do I find them?
Old 01-26-2014, 11:57 AM   #7
In about the most inconvenient location. The sensor is on top of the center of the tranny and the connector in on the back of the tranny:
Old 01-26-2014, 01:54 PM   #8
Geoff Peace
Drives: Yaris 1.33 litre 2011
Just to add. I would test the switch and connector in situ before going to the trouble of removing it. It may be a corroded connector, a broken wire, or the switch plunger may be stuck, or the switch may need adjusting. Always worth a try to save a few pence!
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 01-26-2014, 01:57 PM   #9
Mongoose7
Drives: 2007 Yaris HB
Yes, check out the wires coming out of the switch, a mouse ate through one of my backup light switch wires!!!!!!!!
Mike
Mongoose7 is offline   Reply With Quote
Old 01-26-2014, 09:16 PM   #10
jaimico
Well it's nice to know where it is, and yeap, it's going to be a pain to get to it, I'll keep you posted.
Thanks a lot!
Old 01-26-2017, 10:49 PM   #11
7:34pm
Drives: 07 Yaris
Attachment 52709
Hey I'm having the same problem and trying to figure this out. Both bulbs are good but the reverse lights won't come on.
What exactly is the bottom end of the arrow pointing to? I can't quite tell from the diagram. Also should this be done with the car on or off, or in accessory mode?
Thanks
7:34pm is offline   Reply With Quote
Old 01-28-2017, 12:24 PM   #12
7:34pm
Drives: 07 Yaris
Thanks
Nvm, just checked and the wire is broken. Going to solder it back or something.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
No parking lights ryufrank In Car Entertainment + Electronics (audio / video / alarm) 0 10-06-2013 09:28 AM
Clazzio MicroImage problems please help boggydee Cosmetic Modifications (Exterior/Interior) 1 08-24-2012 04:16 AM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
JUST GOT MY JDM TAIL LIGHTS!!!!! falkor_99 Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 11:25 AM
