Old 01-28-2014, 03:53 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
new water pump
New pump at 151000 km started to leak at the bearing ...fun job around an hr to do .
Old 01-28-2014, 03:54 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
did you have to lower the engine to get the long bolt out?
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 01-28-2014, 03:58 PM   #3
It says you need to lower it a little to get the pump past the frame..
http://www.yarisworld.com/forums/showthread.php?t=12727
mine went around 56k km, bad bearing, but did not leak.
Old 01-28-2014, 04:19 PM   #4
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
All modern Yota's weakest link. I am gonna do a preventative flush soon, no issues yet at 72k, wifes Camry ok at 35k, flushed it at 30k
Old 01-28-2014, 04:50 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I raised the engine ...but u can do it either way problem was that the bloody studs would not go back in if so one could just slide the pump in with help of pry bar ...so engine mount out and I jaked up the motor ..just enuf to make it all fit. ...best part is that toyota yaris pump cost me only 56$ plus coolent and hr of my time.
water pump change 2sz-fe finnpoulsen DIY / Maintenance / Service 5 03-25-2020 10:20 AM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
