Old 01-28-2014, 04:04 PM   #1
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Oil consumption issues in Yaris?
Are they common in Yaris with the 1.5 liter gas engine sold in US? I'm active on Priuschat and apparantly it's common in prius with the same engine (+ Atkinson cycle) to develop oil consumption over 150,000 miles.
jack black is offline   Reply With Quote
Old 01-28-2014, 04:11 PM   #2
I haven't heard any high mileage Yaris owners complain of oil consumption, so it may be that the extra compression of the Prius' 1NZ-FXE is to blame.
Old 01-28-2014, 05:04 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
And 0W20 oil its like water
Old 01-28-2014, 05:36 PM   #4
RJay
Drives: 2002 Toyota Yaris T-sport
5w30 is reccommended over here for those engines.
But how about having a look inside the head of the engine?
Usually valveseats/seals whatever or pistonrings are causes of oil consumption. My T-sport with the 1NZ-FE went through about half the measure on the dip stick(Maybe less, I didn't check the oil level at delivery....) in about 2500 miles, nothing too shocking but compared to my old panda where I'd just change the oil once a year and be done it's a bit extra.
But meh, I'll just swap out the oil in the summer again and that should be that.
198X BMW E30 modified race car
1975 Ibanez "Les Paul custom"
RJay is offline   Reply With Quote
Old 01-29-2014, 05:02 PM   #5
nookandcrannycar
No oil consumption issues with my Yaris at 272k + miles .
Old 07-05-2018, 12:20 PM   #6
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
435476 miles here. Burning 1qt a week. Anyone know if we also got that extended engine warranty like the 2liter guys did?
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 07-05-2018, 12:48 PM   #7
dogsridewith
Drives: 2007 2-door hatchback
435k miles...there's obviously going to be warranty coverage for oil consumption.
Old 07-05-2018, 02:08 PM   #8
barebonedvitz
No need to be a dick noob
They've done Corolla and Camry engines with over 250K and still did it because it was within 10yrs.
Old 07-05-2018, 03:36 PM   #9
dogsridewith
Toyota Warranty Intake Specialist will request conversion of quarts/week into miles(kms)/qt(liter).
Old 07-05-2018, 05:06 PM   #10
zoidberg444
zoidberg444's Avatar
Your engine is just worn out mate. Either get it rebuilt or get it replaced with a low mileage used one.
UK to Nordkapp in a Yaris
Old 07-05-2018, 08:49 PM   #11
Only the 2AZ-FE had extended warranty due to excessive oil consumption.
Sent from my SM-G930W8 using Tapatalk
Old 07-06-2018, 12:33 AM   #12
zoidberg444
I'm sure that engine had issues with head failure due to the threads for the head bolts giving out too.
Sent from my SM-G930F using Tapatalk
Old 07-06-2018, 07:05 AM   #13
Are they giving out? Pretty sure it was something about the cylinder seal. Anyways, let's stay on topic with the 1nz.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
