Old 02-04-2014, 08:41 AM   #1
docB
Drives: '09 Yaris Sedan
Seat wear
Does anyone have an issue with the driver's seat bolster wearing? Mine has killed the foam and worn a hole in the cloth. The metal frame has a sharp edge. From getting in and out, it must have cut into the foam and then the seat cloth. Please relate any issues you may have found like this. I'll try and put up a picture.
docB
docB is offline   Reply With Quote
Old 02-04-2014, 09:12 AM   #2
perhaps because you sit on the edge when you go in? I put my ass in the middle of the seat when i go in.
no wear and tear on my late 06 Yaris with about 86k miles.
Old 02-04-2014, 09:18 AM   #3
I have seen quite a few people with that issue now. Take a look at the thread below that I put together on how to change the cushions. They are quite expensive from Toyota, but you may be able to find used seats for cheap at a local junkyard. The thing that causes the failure is people pushing on the seat back to get themselves out of the car. If you look at the picture in the thread below of the bare frame you will see the two frame wings that end up poking though. For those replacing seats or cushions for this reason, I would suggest putting some type of edging on that sharp metal to prevent it from happening again.
http://www.yarisworld.com/forums/showthread.php?t=49137
Old 02-05-2014, 06:31 PM   #4
docB
Thank you CTScott The big problem is the vendor left a sharp edge on the seat frame. I bet there are two types of Yaris seat. Those with holes and those about to have holes. Anyone think this will be covered under warranty? It is a manufacturing issue as much as anything else.
doc
Old 02-06-2014, 10:26 AM   #5
bitz767
Drives: 2010 Black Manual 3 door
I had mine replaced under warranty once. It has already done it again
bitz767 is offline   Reply With Quote
Old 02-06-2014, 02:50 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
I've got almost 80K miles on my '07... and the seats still look just like new!
Old 02-06-2014, 03:18 PM   #7
I believe that the problem directly correlates to the size and flexibility of the driver. The set of cushions that I sold to someone with this problem came off a car that had over 100K miles on it and they still looked like new. With the other seat that I swapped out for another person, I met that individual, and he was a very large person.
DIY - Replacing the Front Seat Cushions CTScott DIY / Maintenance / Service 6 10-04-2016 06:39 PM
seat upgrade needed-options? OTB Cosmetic Modifications (Exterior/Interior) 8 12-12-2012 09:01 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
Fabric Wear On Driver's Seat Darth Gilbert General Yaris / Vitz Discussion 18 04-28-2007 07:13 AM
