Old 02-06-2014, 07:08 AM   #1
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
I've browsed a bit but need help.
I'm looking for an exhaust tip for my '13 Yaris.
My issue is that the last one I got, it stuck out bad.
I'm looking for a smaller tip this time around.
Suggestions, point me in the right direction?
What's the diameter of my pipe anyways? >_<
Thank you!
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 02-06-2014, 07:27 AM   #2
Used to be that the stainless tips available at Walmart always got recommended whenever someone posted like this. I have one of them as well on my winter mode OEM muffler. Mine is a small one, only 2.5" diameter.
Old 02-06-2014, 08:16 AM   #3
this will do
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 06:10 PM
headlight screw size holding plastic bit jamsie81 General Yaris / Vitz Discussion 0 10-13-2011 01:14 PM
Feeling a Bit Overwhelmed With the Choices for 2011 Yaris...Need Some Advice Britkaza New YARIS Purchase Forum 3 04-16-2011 06:57 AM
is our ecu the 64 bit or 32 bit yarisdarkness General Yaris / Vitz Discussion 2 09-02-2007 06:09 AM
My Toyota badge is a bit loose.... petesimac General Yaris / Vitz Discussion 18 07-29-2007 06:28 AM
