Old 02-07-2014, 08:59 PM   #1
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
Muffler Delete
Hey all, I'm playing around with the idea of replacing the exhaust from the axle back with just a pipe. I do however have a couple of questions. Have any of you tried this, and how was it for daily driving? My second question is does anyone make a bolt on pipe to replace the rear section so it would be easy to switch back if it proved undesirable ?
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 02-07-2014, 09:43 PM   #2
It's going to be loud.
however, i've heard a yaris with a muffler delete, but the owner also did a split, about 2ft back, and loops it back into the pipe about 1ft before it ends. Not sure if you understand.. this will muff some of the noise. and it did sound good.
Old 02-08-2014, 12:30 PM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That's a valid principle.
The sound waves are split up so that part travels another route which puts it out of phase with the rest. Then the out of phase waves are recombined and tend to partially cancel each other out. There are some mufflers that do this internally...
...and even some that do it with external pipes.
Greg
Old 02-08-2014, 11:05 PM   #4
https://www.youtube.com/watch?featur...v_3Pqv_E#t=178
https://www.youtube.com/watch?v=gilFGnewu6E
Old 02-09-2014, 12:57 AM   #5
Silver Streak
Thanks Illusion I had seen these, but still hard to tell how much louder it would be than my Trd when driving.
Trd Exhaust
Trd Rear Sway Bar
Old 02-09-2014, 01:07 AM   #6
tooter
play every day
tooter's Avatar
I think it's funny when people put their phones in the worst possible place, directly in the line of fire from the exhaust pipe, and it knocks them over!
https://www.youtube.com/watch?v=YectX1tadpg
Old 02-09-2014, 04:54 AM   #7
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
I removed the catalytic converter from my Corona and that made a difference to the sound and performance while keeping the stock muffler.
JudgeM is offline   Reply With Quote
Old 02-10-2014, 07:08 AM   #8
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Does this help? Taken from 3ft away, revving to 3100rpm. After SeaFoaming the engine, there is no drone at highway speeds. (I cant prove this, but thats the only change during the time between the going from the Res-back to DC sport back to the Res-Back)
DC Sport Axleback: https://www.dropbox.com/s/h8l28gm71l...DC%20Sport.wav
Resonator Back (straight pipe): https://www.dropbox.com/s/iesbvnv8xs...Res%20Back.wav
Check out my Build thread:
Old 02-10-2014, 06:03 PM   #9
Silver Streak
EZhacker1, I tried to play it and it says there's nothing there.
Trd Exhaust
Trd Rear Sway Bar
Old 02-10-2014, 06:36 PM   #10
It's not that loud, but it is louder than stock. I don't know an off the shelf replacement pipe -- you'd need a flange and some bent pipe, because the flange from the midpipe points up t the undercarriage.
Old 02-11-2014, 12:42 AM   #11
ezhacker1
ezhacker1's Avatar
Fixed the links. I simply just sacrificed my stock muffler, and had a pipe welding and bent to center exhaust. (Not ideal, for flow, but cheap and works).
I plan to redo the testing. The recorder had bass cut on... so doesnt show the whole audio dynamic range. Hope to do more exhausts from people around me.
Old 02-11-2014, 02:35 AM   #12
tooter
play every day
tooter's Avatar
The straight pipe actually sounds pretty dang good!
Here's my Magnaflow exhaust with a resonator tip added to smooth it out more.
http://www.youtube.com/watch?v=FL4CcjF8Z18
Old 02-11-2014, 09:49 AM   #13
Silver Streak
Sounds good you guys.
Trd Exhaust
Trd Rear Sway Bar
Old 02-18-2014, 04:12 PM   #14
I've done it before. Made my own straight pipe from hacked-up bits from a spare Borla axle back muffler I had for my Echo. Sounds Ok, but a lot louder than running the Borla. I ran a header, stock mid pipe and the straight pipe. Sounds like touring car, if you've ever heard one on track. Matched with my 6 speed close ratios transmission it sounds pretty cool pulling on the the highway, but gets old fast, and I think it made less power than running the Borla for some reason.
Old 02-18-2014, 07:24 PM   #15
JustPassinThru
Drives: No more Yaris
Yup.
The engine is designed to run with, and the microprocessors tuned to, running with a certain level of back pressure. Drop that back pressure and conditions are out of design specifications; and depending on the computer controls, it might read it as an abnormality and retard spark or enrich fuel. Lower performance.
JustPassinThru is offline   Reply With Quote
Old 02-18-2014, 07:29 PM   #16
Well the Borla is a straight through glass pack type muffler so the back pressure should be the same on both pipes. I have a feeling i didn't put the connection together tight enough and was causing some vibration through the exhaust causing the knock sensor to pull timing. It was mostly in the lower RPM range.
modify stock axle back muffler what do you think AND189 DIY / Maintenance / Service 15 12-21-2009 08:23 AM
Doug Thorley header + muffler delete curik Performance Modifications 4 11-04-2009 07:48 PM
Rusty Muffler dadi_oh Cosmetic Modifications (Exterior/Interior) 7 07-03-2009 09:45 PM
Aftermarket muffler. THiS KiDD Performance Modifications 17 11-12-2008 10:00 AM
Rusty Muffler Hangers YAR1S General Yaris / Vitz Discussion 14 10-24-2008 08:22 PM
