Old 02-10-2014, 09:09 AM   #1
esse10
Drives: 2009 yaris 2 door
Throttle body coolant lines
I have a small leak and it seems to be coming from around the throttle body area but can't really tell. Are those two lines under the throttle body the coolant lines? the ones that the red arrows are pointing to?
Old 02-10-2014, 10:03 AM   #2
Yes they are. You can actually connect the two hoses together (with a piece of pipe in between) to bypass the coolant flow through the throttle body, if the leak is from the throttle body or its pipes. The only purpose of that is to heat the incoming air for emissions purposes.
Old 02-10-2014, 10:45 AM   #3
esse10
cool
k, thanks you the MAN.
Old 02-11-2014, 12:43 AM   #4
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Hope much of an intake temperature difference would it make when bypassing?
Check out my Build thread:
Old 02-11-2014, 07:57 AM   #5
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I can only talk about the 1KR-FE, but I had 5...15K above ambient temperature, even with some kind of cold air intake.
Old 05-10-2020, 12:09 PM   #6
cmronald
Drives: Toyota Vitz 2007 (1KR-FE)
Isn't that for anti-ice purpose of the throttle valve.
cmronald is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
How to throttle body coolant bypass? kliwonz DIY / Maintenance / Service 0 05-24-2010 12:50 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
