Old 02-14-2014, 07:04 PM   #1
barefoot_bajan
barefoot_bajan's Avatar
Drives: 02 vitz rs
Door Locks Not Working
Hi Guys,
I have a friend who's told me her door locks don't work, she can only unlock one door.
so I went checking and apparently her central locking works but the locks don't move they stay in locked position, and only the drivers door works(when it feels like it).
after a few questions, she finally said her daughter plays with the locks and when she tries to unlock the doors her daughter keeps her hand on the lock so it doesn't pop when the others do.
I can hear and feel the actuators in all the doors working when you use the keyless entry. what can be done to get all locks working again?
barefoot_bajan is offline   Reply With Quote
Old 02-14-2014, 07:05 PM   #2
barefoot_bajan
Drives: 02 vitz rs
Did I mention, its a 02 vitz rs like mine.
Old 02-14-2014, 07:34 PM   #3
If they are being fought while moving, then the lock actuators are likely damaged (most likely the little plastic drive gear is stripped).
Old 02-19-2014, 03:11 AM   #4
barefoot_bajan
Drives: 02 vitz rs
thanks CTScott.
Would you happen to have an image of these plastic bits?
Old 02-19-2014, 08:24 AM   #5
Originally Posted by barefoot_bajan View Post
thanks CTScott.
No. Unfortunately I didn't snap pictures when I had one apart.
Old 02-19-2014, 03:31 PM   #6
jcboy
Drives: Sedan 07
you can get a set of aftermarket actuators (cost 10 bucks a set here where i am).
the thing with the yaris is that the locks and door openers are cable operated, as compared to a stiff metal rod in the civics/corollas of yesteryears.
that would make it a pain to retrofit aftermarket actuators. [Scott, thoughts?] unless you strip the rubber cover of this and do the retrofit as you would to a rod-type setup.
like this:
Old 02-19-2014, 03:38 PM   #7
I have installed aftermarket door actuators on two Yaris and with the cable you do have to strip off the outer plastic jacket and snip the wire cage that surrounds the cable.
Since the O.P.'s car has OEM lock actuators, I would just track down a good used one and replace it with the OEM actuator.
Old 02-20-2014, 09:45 AM   #8
Brett!
Drives: 2010 3D base
Scott said this was fairly easy and I plan to do this myself next week. If I can do it anyone can - I'll report back when I have installed mine.
Brett! is offline   Reply With Quote
Old 02-20-2014, 11:10 AM   #9
the 02 vitz have a rod locking mechanism like the echo.
cargo light not working? ( Yaris HatchBack ) theyaris123 DIY / Maintenance / Service 7 05-22-2017 04:49 AM
Remote alarm not working kropekoi In Car Entertainment + Electronics (audio / video / alarm) 2 01-15-2013 10:16 PM
Valet 712t not working yaris prime In Car Entertainment + Electronics (audio / video / alarm) 2 04-23-2009 07:53 PM
Working at Volkswagen elsteverino889 Off-topic / Other Cars / Everything else Discussions 22 05-07-2007 08:29 PM
