Old 04-11-2007, 12:13 PM   #1
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
Real World Test: Yaris vs Yaris
cleong is a good buddy of mine, and we brought our cars up to a windy stretch of 2nd-3rd gear roads. We wanted to see how different our cars felt.
cleong's silver yaris:
1.5l 5sp manual
TRD springs
1.8 degree camber bolt
Zero toe-in upfront
Buddyclub P1 replicas 15 x 6.5"
Michelin Preceda II 195/55r15
nurburgring's black yaris:
1.5l 4sp ECT
Tanabe NF210
no changes to suspension geometry
Buddyclub P1 replicas 16x7"
Dunlop SP Maxx 195/50R16
Ride comfort:
Although having 16" wheels, my car (nurburgring) felt softer and I felt rode better. Just a tiny bit stiffer than stock. In fact, I dont have to slow down too much over speedbumps. I should attribute this to the NFs being clearly softer, especially in the back. Tyre noise for both cars is actually pretty good, with the Preceda's (according to cleong) being a tad quieter. To me though, I felt my tyres were quieter. *shrugs*. The Preceda's squeal more easily (still requires a massive dose of provocation), which is a good thing I feel.
Handling:
Quite different I would say. cLeong has a lighter, and more direct steering. Turn in felt sharper. It is immediately noticeable. I'll attribute this to his suspension geometry. Grip levels for both cars are very high, with the cleong's car pulling higher G's before breaking traction. Both cars feel progressive at the limit, although I must the Dunlops dont squeal much, so you gotta feel it. I think progression wise, my geometry was more friendly due to the slightly stretched tyres and more positive camber, cleong's car had a higher grip level, but when it understeers, it chatters a bit. I felt that my car was less grippy, as the car was riding on the outer edge of the tyres too much, so much so the sidewalls were bending. It felt soft at the limit. I think a -1.2 degree bolt will change things. I like the way cleong's car felt in corners, very flat.
We had tons of fun, exchanging cars, sitting in one another's car, and in the end, going together for the run. Obviously, he had more balls than me. I could only smell smoke.
But I'm happy I made a good choice to my tyres, quiet yet grippy. THe NFs felt good too. But less sporty than the TRDs.
cLeong, your take ?
nurburgring is offline   Reply With Quote
Old 04-11-2007, 12:46 PM   #2
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
nurburgring's (henceforth Marc) got our setups pretty well memorized. I'll only add on that I have tire pressures set at 230kPa front and 210 kPa rear.
Our test circuit is a curvy section of downhill road about 2 miles long. The gradient is generally less than 5%. We did descents as well as hillclimbs.
I took each car down at an approximately-constant 45mph(60-70kph), since one is manual and the other is auto. That helps take transmission out of the equation and we can concentrate on the handling.
Between the two cars, I feel that Marc's car has higher sustained cornering limits due to the footwear. However my car (as said) has a better turn-in and tires are more progressive. I can "convert" the neutral attitude toward planting throttle earlier to set up for the corner exit.
I cannot objectively judge Michelin Pilot Precedas for their grip levels (no basis for comparison to others) but their transition from grip to slide and back is the best I've tried so far (I've got time on Yokohama Aspec DBs, Falken Ziex, Bridgestone GR80).
Dunlop SportMaxx are new to me, and it took me a while to learn their limits. They are impressively high, and appeared to take more lateral Gs before losing traction. Marc complained about the sidewalls rolling; I have to say I can't feel it. I do know that the grip does fade more rapidly the harder you corner. The wider tires give better grip, and also gave the steering a nicely weighted feel that was less "woolly" than my own car.
The fact that the TTE springs are lower in the front are probably an important factor in the handling difference. I've said before that the difference in ride height shifts the CG forward a little. I like how the car pivots nicely around the front wheels when I turn in. That sort of sensation was picked up by Marc as feeling like the rear end was a little unweighted.
The front end of my car received attention from the setup guy who put in the camber and took out the toe. The net effect is that the car grips pretty well under hard cornering, and it has a generally darty pointy feel if you like that sort of thing.
It is probably hard to say which single factor contributes to the differing feel (as described by Marc). Could be all of them. But car setup is a pretty personal thing, some people like the security of understeer, I prefer to drive the front end of the car and let the rear follow. I can use the throttle to control the initial turn-in pointyness to turn it into productive understeer out of the corner.
That being said, we drive at fairly sensible speeds (less than 60mph) to learn the mechanical grip limits of the cars. As such there isn't much hard braking to unsettle the rear end. Driven at 10/10ths my car would probably be quite prone to spinning out going into bends.
I would look to dial out some front grip if I was going to bring my car to the racetracks.
Old 04-11-2007, 12:52 PM   #3
cleong
cleong's Avatar
I think I should sum up the two cars in a separate post.
The way my car is set up, its a front end biased car, and more fun for the twisties.
Marc's is fairly stock suspension geometry wise, and is the safer car. Its probably more ready for aggressive track driving given that it has a more neutral suspension balance.
Old 04-11-2007, 01:02 PM   #4
good review, both of you. sounds like a fun event. heh. for future reference, what do you guys recommend on wheel/tire size?
Old 04-11-2007, 01:08 PM   #5
nurburgring
ringmeister
Drives: YARIS 1.5
I will still go 16" for looks. But we are different people I guess. I'm all out for looks, and leong is all out for performance.
Despite having taller side walls, cleong's car had more direct steering. His wheels are probably lighter as well.
If you go 16", I would highly recommend 195/50R16, very similar to stock diameter. Or 205/50R16 if u have a bit of camber in front.
Old 04-11-2007, 02:32 PM   #6
YarisGuy
Drives: 2006 Yaris
This is a great thread and some interesting reading. Thanks for the post and keep it up :)
YarisGuy is offline   Reply With Quote
Old 04-11-2007, 02:42 PM   #7
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
yea nice post..
-- Blen
Old 04-11-2007, 02:45 PM   #8
Blenjar
Blenjar's Avatar
Question: Should I go coilcovers or just hit hte springs?
-- Blen
Old 04-11-2007, 06:58 PM   #9
cleong
cleong's Avatar
-- Blen
The answer is that it depends. If your favourite stretch of roads are the single lane back roads, then I think it would be fine to just get springs. These lowering springs (both Tanabe and TTE) are listed as cosmetic mods.
The stock dampers can't cope with speeds over 60mph (driving on twisty roads) at least on my car - the car gets floaty and choppy and quite seriously scary. The undulations in the road come too fast for the car and you're left reacting to sudden twitches that you never knew was there when you drove at slower speeds.
I'd just get adjustable shock absorber inserts than full coilover jobs though. Koni, where are you?
Old 04-11-2007, 06:59 PM   #10
nurburgring
ringmeister
Drives: YARIS 1.5
-- Blen
For a driver that wants the drop down look, good compromise of ride comfort/handling and affordability, I'm happy I went for springs.
Coils are way expensive, and way hard.
U mentioned TRDs or NFs for a highway driver who cares for looks,
I'ld say go for NFs. TRDs offer stiffer spring rates and may be too busy for you. But its subjective. Consider also, that NFs are lower behind. U may or may not like that.
Old 04-11-2007, 06:59 PM   #11
cleong
cleong's Avatar
You may want to go 205 next time round - tire profile would be less stretched.
Old 04-11-2007, 07:03 PM   #12
cleong
cleong's Avatar
Recap of our cars:
Marc's (nurburgring):
Leong's (cleong):
Old 04-11-2007, 07:07 PM   #13
Blenjar
Blenjar's Avatar
My current tires on my 17 inch 7.5 are 205 45 17. wat would u recommend after these are done?
lol let's not forget a picture of my car...hehehe
-- Blen
Old 04-11-2007, 07:15 PM   #14
Blenjar
Blenjar's Avatar
damn ur pictures r still nicer..
im take better one another day..
-- Blen
Old 04-11-2007, 07:17 PM   #15
cleong
cleong's Avatar
Depends on how much it rains up there. If its wet often, Pilot Sports. If its not, Yokohama AD07. Are these available there?
Old 04-11-2007, 07:35 PM   #16
Blenjar
Blenjar's Avatar
Yokohama is here, not sure about Pilot Sports..never heard of them..
-- Blen
Old 04-11-2007, 09:07 PM   #17
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
good show.
Old 04-11-2007, 11:47 PM   #18
Originally Posted by cleong View Post
Recap of our cars:
Leong's (cleong):
hehhe you guys literally are the Buddy Club Buddies
Anyway that was some great research you guys did, can always count on the kiasu singaporeans to over-analyse things (just kidding!) We oughta meet up whenever I go down to your little island next!
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
I finally test drove a Yaris Hatch... ECHOKnight2000 New YARIS Purchase Forum 10 02-01-2007 12:18 PM
