#1 |
Toyota Echo NOOB!
Drives: 2005 4dr Echo hatchback Join Date: Oct 2013
I am looking at finding some coilovers and heard that 1st Gen scion Xb coilovers might fit in 2000-2005 toyota echo hatchback...
I am looking at these racelands http://www.racelandus.com/coilovers/...s-1st-gen.html Also look--http://www.ebay.com/itm/D2-Racing-RS...-/380696034851 Has anyone ever tried Xb suspension in their echo or know if this works? I emailed raceland to ask them to see if they knew or not. But also figured i would post here Here is the car it will be for ![]() ![]()
2005 Echo hatchback Project (Silver) Instagram: Lawrencephotography |
email raceland to make sure i wanted to use a set on my 07 yaris but to make it work i would have to relocate my sway bar location mount cos its missing on the coilover..echo sway runs off the control arm so u maybe ok.
#3 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
first gen xB suspension setup is identical to the Echo. Weight differ, so lowering height will be different than xB.
#4 | |
Toyota Echo NOOB!
Would most likely not lower the echo a substantial amount...?
#5 |
If they are coilovers, isn't ride height adjustable? So it wouldn't matter about the weight of the vehicle?
| Will 14" Echo Wheels fit an '08 Yaris? | John Lenin | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 07-20-2012 03:31 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| Toyota Echo 2005 compresor a/c | xavier19 | Caribbean | 0 | 05-10-2012 10:46 PM |
| Confused...vitz, yaris | iLikeVitz | General Yaris / Vitz Discussion | 10 | 07-24-2006 03:24 PM |
