Old 02-19-2014, 02:16 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
FS: Engine & MT - $300
Selling the engine and manual transmission out of my car. The motor is currently still in the car and has not been pulled yet. The reason I'm selling it for so cheap is as follows, it needs a new clutch, there is a small oil leak from the driver side half shaft seal, and first grinds occasionally and third grinds occasionally when shifting at high rpm.
The reason I'm replacing the drive train is that this is out of my racecar and I am replacing it with a motor that produces slightly more power.
Engine has 12~k doesn't burn oil, or smoke. Will provide a video shortly of the car running to prove that the engine doesn't knock or make noise. Motor has been run with only synthetic since 36k miles, all oil changes were done at 6k mile intervals.
Transmission is from a junkyard not sure on mileage, it works but as noted above it grands when shifting into 1st and occasionally grinds when shifting into 3rd at high rpms, along with a small oil leak from the driver side axle seal.
The motor will need a new clutch, the current clutch doesn't slip but grabs really really high so I'm assuming its on its way out.
I'm located in SoCal and shipping would be prohibitively expensive.
As promised here is a video of the engine running. The rattle in the video is from the exhaust hanger.
Engine running
Old 02-19-2014, 03:04 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Damn, this would be a great core for a forged internals build. Could you at least humor us with a freight quote in the US?
Edit* Disregard, just played with some numbers on FedEx. Ouch.
Old 02-19-2014, 06:38 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
UGHAAAAAAAA... why you live on west coast.. WHY FOOL WHY!
-Derrick-
Old 02-19-2014, 06:53 PM   #4
Awesome core for a build. Interested.
Old 02-19-2014, 07:02 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
oh cool, since Garm sold his Yaris he want to start building engines for people, awesome, when are specs going to be posted....
Old 02-19-2014, 09:33 PM   #6
xnamerxx
0-60 in slow
xnamerxx's Avatar
Updated with video of the running engine.
Old 02-21-2014, 04:05 PM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
Motor is out of the car. Minus the header and belt, basically everything in the picture.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Can I change my yaris engine from 1.3L to 1.8L Rami yaris Performance Modifications 9 06-11-2012 10:21 AM
