Old 02-19-2014, 03:31 PM   #1
chris80
Drives: toyota yaris
brake lights not working yaris 58 plate
My 2 lower brake lights have stopped working, the window one is still working.
Changed bulbs still nothing. Looked under dash at fuse box, on the front of the fuse box it says STOP but there is a line through this and no fuse present unless i am mistaken. Checked the fuse marked tail this one looks ok.
Any ideas on what else it could be or if i have done anything wrong in tge above step.
chris80 is offline   Reply With Quote
Old 02-19-2014, 04:14 PM   #2
It should be the STOP fuse. Looking at the European EWD there isn't a configuration where the stop fuse is not used.
Old 02-20-2014, 03:45 PM   #3
chris80
Thumbs down
My mistake had another look today, it was the 1 above the STOP writing not below.
Checked fuse looked ok but i changed it anyway, still not working.
Old 02-20-2014, 04:11 PM   #4
OK. If the fuse is good and the 3rd brake light is working, then there should be power back there. If you have access to a multimeter, measure the voltage to ground at the bulb socket with the bulb removed. Also measure the resistance between the bulb socket's ground (the outer round area) and the chassis ground of the car.
Old 03-21-2018, 08:00 PM   #5
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
Sorry to revive this, but man I really with there was more in this thread. Im having the same issue (tail light brake lights not working, but 3rd brake light is). I was reading some general troubleshooting and it said the actual switch on the steering column might be bad. Anyone have any knowledge on all this?
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 03-24-2018, 12:33 AM   #6
B.B._07
Drives: 07 5dr
If your 3rd brake light is working but the lower ones aren't than it's not brake pedal switch. Best bet is to pull the bulbs that aren't working and check the power and ground wires with a test light. The multi meter method like CTScott suggested is another good method.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
